Hold fast locking latch - tour Pak mount for M8 Softail.
RossW
5 years ago
Quite honestly, it doesn’t work at all on a Tour pak mount. It is exactly the same as the hold fast sissybar mount locking latch and it works fine on those.
Here, it secures and locks ok, but there isn’t quite enough room to turn the key, and when you do get it unlocked, it won’t lift far enough to get into the upper notch. I don’t know if this issue is confined to the FXLR/FLSB version, or if it’s the same for all.
Does no-one at HD check these things?
