Online: Soapbox2627, beaglebasher
Fault Codes B2141, B2156 LHF-RHR indicator output open
  • Deputy Dog
    Deputy Dog
    5 years ago
    Gents need help to sort out these codes. A mate changed his battery on a 2018 Softail Deluxe M8 but he got the leads crossed. He called me to help so i changed the battery leads around and started to check for faults. Could not clear the codes as the indicators would not work. I had a new BCM spare, installed and configured the BCM. Tested the bikes indicators and the faults were still present. Could the fault be in the speedo?
  • dicko
    dicko
    5 years ago
    Yeah, I think the signal module is separate from the ECM
  • STEAMER
    STEAMER
    5 years ago
    Had his battery shit itself so soon.
    Have you checked All fuses.
  • Deputy Dog
    Deputy Dog
    5 years ago
    The 7.5 fuse had blown when he turned the ignition on. He replaced the fuse before I got to it. The fuse has not blown since, so I thing the damage has been done to those to cuicuits.  LHF & RHR indicators don’t flash.
    5 years ago
    Quoting Deputy Dog on 23 Jul 2020 11:26 PM
    Thats bloody odd... as the unit only has 2 outputs (1 x left and 1 x right) - well thats the case on my 09 Sporty.
    - Could the bulbs be buggered in the non flash units
    - Could the earths or something be buggered?
