Online: Soapbox2627
Centre punch.
  • Far Canal
    Far Canal
    5 years ago
    Been a bit deflated with the performance of my centre punch and want to get something that is good quality.
    Looking online I see there are ones you do not even need to hit with a hammer!. Not sure I need one that fancy....or not.
    So, who has got an excellent centre punch recommendation?
  • steelo
    steelo
    5 years ago
    Something like this FC. Auto centre punch.
  • Far Canal
    Far Canal
    5 years ago
    I want one I can hit with a hammer Steelo.
    5 years ago
    Quoting steelo on 21 Jul 2020 10:36 AM
    HAd one of them for 30 years, little rippers to use.  Get a top brand one though - none of that chineese chit.
  • Wideglider
    Wideglider
    5 years ago
    Quoting Far Canal on 21 Jul 2020 10:42 AM
    Jeez FC, embrace the newer technology.
    I guess some blokes want to use their hammer at every opportunity!
  • beaglebasher
    beaglebasher
    5 years ago
    This question is a bit spooky  FC.
    I recently made myself a center punch out of a  miners pick type of thing.
    It was a little bit heavy so I  put it in the lathe and took some metal off the body of it but I left the hard as fuck tip .
    I sharpened the tip with the soft green grinding wheel ( took ages)  but by the time the wheel disappeared I had this big fuck off center punch.
    It was a fukin beautiful thing to smash with a 2  1/2 lb   ball peen hammer.
    I used it a few times and all was good.  Then I had to use it on a 10mm cheese head screw and it broke.
    I am in the same boat as you mate.  A decent center pop  would be good
    5 years ago
    Checked and my one is an old Starrett adjustable pressure unit.
  • bloodog
    bloodog
    5 years ago
  • beaglebasher
    beaglebasher
    5 years ago
    An adjustable pressure center pop is it tuss?    How do you control the pressure ?
    I  heard some clever cunt invented a digital one but I  havent saw it in action yet.
    5 years ago
    Quoting beaglebasher on 22 Jul 2020 11:10 AM
    The middle - top section of the barrel can be turned to adjust the pressure of the impact (basically it just loads/unloads the internal spring).
    Its handy if your doing soft materials as the hardest setting can punch a hole through some materials
  • beaglebasher
    beaglebasher
    5 years ago
    As I  mentioned before I need a decent fuck off center punch.  Any recommedations what to buy?
  • steelo
    steelo
    5 years ago
    Did ya get ya centre punch fc?
  • Far Canal
    Far Canal
    5 years ago
    I got the best one I could find at Bunnings. Not particularly happy with it but at least the steel it is made from seems to be quite hard. Still on the lookout for a better one.
  • beaglebasher
    beaglebasher
    5 years ago
    I ended up buying one from a local tool shop. Same as you  FC, not totally happy with it  ( not big enough ) but  not too bad.  Made in Germany.   $18.
  • Far Canal
    Far Canal
    5 years ago
    Quoting beaglebasher on 12 Aug 2020 08:53 AM
    Yeah the one I got was pretty pissy really. It was not made in China for one, so I was happy with that.
    What I did not like about it was the blunt angle on the business/pointy end. It made it hard to see the exact spot where the point is before you hit with a hammer, without craning your neck and then viewing from an ambiguous angle.
    I guess I should grind a steeper angle on it and see what gives.
