Online:
Stuart
Lowered 2016 iron 883 exhaust
Bts838
5 years ago
I have a16 iron 883 lowered on 11.5 inch progressive shocks, with a set of magnaflow bandits, similar to short shots.
My problem is turning right. Scrapes at the slightest lean, and has popped the landing ring off the exhaust so now have a massive leak on the front jug.
Anyone else have a good exhaust that is capable of a pillion passenger, and doesn't scrape? I am about to order some bassani radical radius sweepers.
5 years ago
You’re very limited in what you can do
when the bike is that low. I suggest longer rear shocks at 12.5 inches. Also anything like short shots are pretty ordinary for street performance. There’s a good chance you’ve gone backwards with this pipe. Your bike probably looks and sounds the way you like but there’s often a comprise on handling and performance
5 years ago
Raise the bike! put on longer shocks (BUT never factory Harley ones as they are total chit)
Or trade in for a 883L (I'll swap you for my 09 883L)
If your in need of a LOW bike then there are low seat options for the Sporty that will provide a lower seat position.
Change the pipes!
Factory headers with Screaming Beagle mufflers is a good combination - I still scrap from time to time but that's only when I'm pushing and its only the mounting bolt heads that touch the ground. Or a customer set of upswept pipes or the like.
Bts838
5 years ago
I don't really want to raise it, I really like the sound of a 2-2. I decided to go a fpe radical high radius.
It's an 883, they go pretty good really for what they are, I just need to be able to lean it over more. I bought the bike how it is, with the stage 1 done. I'm disappointed, because I love the look of the pipes. It fairly gets up and moves in my opinion.
micathia
5 years ago
my 883 is similar to yours. 2013 model on 11.5 shock.
My pipe is side shot. 120db in volume i tested it. Louder than my dyna.
I think for sound and performance, you can try thunderheader or D&D 2-into-1. Performance improve will be noticeable.
For 2-to-2, i just love the side shot.
noctm
5 years ago
I used to have a lowered iron, went through two sets of 2-2 that I scraped the fuck out of before I ended up with a magnaflow 2-1 set that wasn't up swept, looked good and had no clearance issues. I can't think of many/any 2-2's that you won't scrape on a low sporty
