Online: Soapbox2627, beaglebasher
Arlen Ness 14 inch Big Brake Kit
  • TJU
    TJU
    5 years ago
    Hi All … does anyone have a set of the Arlen Ness 14 inch Big Brake Kits fitted to their bikes … thinking of adding some extra stopping power to my 17 RG Special … but they are not cheap … seeing as I have the Twin Disc setup on my ride.
    Mostly I am curious about extra stopping performance percentage wise .. are they a 10% improvement or 50% .. for the cost would I be wrong in thinking anything less than say 25% would not be worth it .
    Fitment issue as well , I am running the 19 inch Harley Turbine front wheel .. are stock disc 11.5 or there about`s  .. by going to the 14 inch would there be a issue with the Calliper being to close to the rim .
  • Birtyyy
    Birtyyy
    5 years ago
    Better upgrade would be radial mounted brembo's and Galfer discs. Check out Big Steve's for sale posts!
  • TJU
    TJU
    5 years ago
    Thanks Birtyyy … will have a Gander .
  • Benno
    Benno
    5 years ago
    Quoting TJU on 17 Jul 2020 03:11 AM
    I put one on a couple of years ago, do a search on here for Ness big brake kit, its better than stock, noticed a difference straight away, noticed even more difference after putting a set of Lyndall brake pads in the caliper.
  • TJU
    TJU
    5 years ago
    Thanks Benno .. Good to know .
  • leachy
    leachy
    5 years ago
    Hi Benno,
    Is there any drawback for using the Lyndall brake pads?
    Regards
    Leachy
  • Benno
    Benno
    5 years ago
    Quoting leachy on 23 Jul 2020 05:07 AM
    Hi Benno,
    Regards
    Leachy
    Not that I have seen yet, some say they are hard on your rotors, I have noticed any change in wear, the rotor is still like new and I think I have put about 25k on it now.
  • leachy
    leachy
    5 years ago
    Thanks Beno, I might try them, I just looking for a bit more initial bite.
  • Chaser
    Chaser
    5 years ago
    I'd definitely be looking at cheaper parts first - pads and brake lines for starters.  I had a 6 pot PM caliper on my Deluxe some time ago - awesome!
  • Benno
    Benno
    5 years ago
    Good point, I did put braided line on at the same time as doing the pads
