Online:
Ratbob
1991 electra classic evo 1340
Trent
5 years ago
Hey Guys,
After some help please.
I currently have a 1991 electra glide classic. 1340
Motor has been fine and running like a dream.
But today i had issues with it. Not sure if it is clutch slipping our not getting enough fuel?
Currently gets in and out of gear fine. Will be riding along and if i try give it more throttle. above 3000rpm i have no power. Like it is not in gear. All noise & no go.
Motor runs fine no coughing smoke etc. Just revs out but won't go any faster.
Fuel was low, but i filled it up and didn't fix the issue.
Any help would be appreciate. Location in Melbourne south east.
Thanks
Smokey61
5 years ago
If it's revving out but not increasing speed, it's your clutch.
Trent
5 years ago
thanks for the reply smokey. So you think it will just need adjusting inside....
Or sounds like a new clutch. Worried my motor was stuffed.
Appreciate your help
5 years ago
Good clean revs and no go is typical clutch slippage...If the revs are breaking up like its misfiring a little then it could be Carb, Coil, Ing module etc.
You should hear the revs rise as the clutch slips
Smokey61
5 years ago
Try adjusting it first. Do you tow a trailer?
Smokey61
5 years ago
If it's out of adjustment, you could try adding an extra steel plate to the clutch plate stack.
