Online: Ratbob
Stripping a Tank
    5 years ago
    Hi,
    I have a factory EFI Sporty Tank that I'm going to repaint/cover/bastardise
    Would normal paint stripper work to remove the paint?
  • Birtyyy
    Birtyyy
    5 years ago
    I've used paint stripper before and it worked well. I've also repainted one without removing paint, just sanded back the clear coat and painted over the top. Both ways had good results
    5 years ago
    Quoting Birtyyy on 09 Jul 2020 01:58 AM
    Awesome... I'm freelancing a copper sheet coating so need a full strip as I'll be using a gas torch to mould patterns etc .  So really need it stripped back to bare metal.  Polystripper here I come!
  • Ratbob
    Ratbob
    5 years ago
    I’ve led a sheltered life, WTF’s a Copper sheet coating ?
  • bloodog
    bloodog
    5 years ago
    5 years ago
    Quoting Ratbob on 09 Jul 2020 08:39 AM
    I'm gonna try an old school technique... how hard can it be!   .lol.
  • beaglebasher
    beaglebasher
    5 years ago
    Quoting tussuck on 09 Jul 2020 01:12 AM
    Hi,
    I am no expert but I was using paint stipper just the other day.
    It said on the label to put it on and wash it off 20 minutes later.
    I left it overnight and expected no paint to be there the next day but
    all the paint was still there.  Only a bit wrinkled and fucked up.
    If youre gonna use paint stripper read the instructions.  And yeah  it will take the paint off the tank
    (if you follow the instuctions)
    Keep us up to date with the paint job tussuck
  • sinny
    sinny
    5 years ago
    if you can find aircraft paint stripper use that - otherwise any paint stripper.
    After that you will likely still need to crack out either the air sander with some 80 grit or just sand it off by hand with 80 grit. It doesn't take that much effort. To get into the corners and tight spots.
    A local sandblaster would knock it off pretty quick - but you need to work quick so you dont get any surface rust.
    Im interested to see how it turns out - remember to take pics!
    5 years ago
    Like me never heard of it. I would have thought setting fire to it would distort the shape as you had no control over what part is hotter than the other?
    5 years ago
    Quoting paulybronco on 10 Jul 2020 10:12 PM
    YEah. I'll use paint stripper.  I only have one Barby and its a nice one so the missus would not be happy to find a tank in it...lol...Its bad enough enough when I put chit in the oven or dishwasher.
