Online:
harderometry, Humbug, Merv
Bar mount rubbers
Bar mount rubbers
Slowen down
5 years ago
Been noticing on some rides lately that there is some vibration in the bars when carving through some twisties.
When moving from a left corner to a right corner there is a slight vibration feeling in the bars.
Thinking it may be bar mount rubbers seeing the bike is 8 years old.
Anyone got any experience whith this.
Read about good neopreme replacement from EasyR?
John.R
5 years ago
Alloy Art, they sell 130k sets a year and supply for harleys 'upgraded' ones.
Says enough
Slowen down
5 years ago
Cheers mate will look them up
noctm
5 years ago
I bought a set of the alloy art ones after putting on some tall tbars. Their polyurethane is quite stiff and I found it actually increased vibration, but they did fix the movement in the bars.
I found the best solution was stock Harley rubbers, combined with the alloy art bolt sleeves. No movement in the bars and much less vibration than the alloy art polyurethane bushes.
