Online: Humbug
Indicator Wiring problem
  • M4rkM
    M4rkM
    5 years ago
    Hi Everyone,
    I'm new to the forum but would love some help with an ongoing issue, I have spent the best park of lockdown getting my street 500 set up the way I want and repairing/servicing. I have hit an issue with my right indicators, they stopped working and it looked like a switch issue, I replaced it and wired up the new switch but during the first test ride the right side stopped, I get no front or rear and no light on the dash, if I reverse the switch I can make the right switch power the lift side fine so I am sure the switch is fine this time, I checked the new connectors and all wires are ok. I even ran a jumper wire to bypass my new connectors back to the main harness connector but no luck.
    What am I missing?
  • Soapbox2627
    Soapbox2627
    5 years ago
    earth, if you have power, cant be earthing
    maybe
  • brucefxdl
    brucefxdl
    5 years ago
    possible broken wire in the harness around the head stem area that flexs when turned from lock to lock .....may be.
    5 years ago
    Step 1.   Do you have a Service Manual or wiring diagram?
    Step 2.  If no then get one from Harley for free here:  https://serviceinfo.harley-davidson.com/sip/
  • M4rkM
    M4rkM
    5 years ago
    Quoting tussuck on 28 Jun 2020 03:32 AM
    Yeah mate I have the wiring diagram and it looks like all the connections are correct, looking at the 2015 diagram I do not see  any issue not sure it I should take the tank off and start eleminating parts of the harness to try to find the break ( if thats the issue) although if it was a brake it would need to be at the control end to effect all the lights.....i think
