Online: tussuck, speedzter
Rinehart Crossbacks for Dyna
  • micathia
    micathia
    5 years ago
    bought it in March 2020
    now:
  • JFE
    JFE
    5 years ago
    So are you getting a new set under warranty?
  • micathia
    micathia
    5 years ago
    Quoting JFE on 23 Jun 2020 10:28 AM
    The local stealer will forward my photos to Rollies, but according to Rollies site, they check the paint before shipping, then after shipping its not their business. Buyers have to take the responsibility to "repaint" from time to time.
    Don't think I can get replacement, but if they can reimburse some money for a repaint, I am happy.
  • WideglidingNZ
    WideglidingNZ
    5 years ago
    I had chrome  cross backs on my previous wideglide with no probs. Usually the black paint is a ceramic type and i'm not sure how easy it is to re paint
    5 years ago
    I had similar issues with the black coating on supertrapp supermeg hearshields. Two times they were replaced without issue and the third time around had nil issues.
  • micathia
    micathia
    5 years ago
    all sorted. I will be given a new shield. :)
  • steelo
    steelo
    5 years ago
    Good result m. What was your approach?
  • JFE
    JFE
    5 years ago
    Quoting micathia on 01 Jul 2020 09:13 AM
    That should definitely happen. Glad it’s worked out that way.
  • WideglidingNZ
    WideglidingNZ
    5 years ago
    did they let you keep the old one for a spare?
  • micathia
    micathia
    5 years ago
    Don't think so. Because they asked if I can detach the shield myself.
  • chopa
    chopa
    5 years ago
    Quoting micathia on 13 Jul 2020 11:34 AMedited: 13 Jul 2020 11:34 AM
    You were lucky the pricks wouldn't replace my Heat shields on a set of Freedom Performance declarations when the heat shield bracket broke after only 14kilometres. Had to send them back and they  re welded and re chromed them. Done a shit job and they broke again 6mths later. Couldn't be bothered argueing with them again and pissed them off and got Bassani's. Under Australian warranty laws seller is to replace, repair or refund and that option is the buyers privelidge not the seller. Refuse to deal with Rollies anymore
  • micathia
    micathia
    5 years ago
    Quoting chopa on 17 Jul 2020 05:41 PM
    Good to know. I will avoid this brand in future too.
