Online: Retroman, Merv
Error code P0661
  • Elimin8r
    Elimin8r
    5 years ago
    Hi guys,
    I have a 2010 Heritage and the other day it gave a backfire through the air cleaner, motor is a 96 cube and supposedly redone to a 103 cube and a stock, i think, air cleaner and also has a set of V & H's on it. Bike was running well, apart from some horrific sounding starts, and when i took it around to the mechanic we done a few starts and then the backfire. Riding around a bit it was like the throttle was on cruise control, holding the revs higher than idle. Eventually dropped down when i got home, now i have the code which returns when you fire it up, none of the other codes cane back, any ideas ?
    Thanks
    5 years ago
    P0661 is for the intake "flap" solenoid.
    Wont cause a hanging idle.
    Was it unplugged at some stage ?
  • Elimin8r
    Elimin8r
    5 years ago
    Thanks Speedzter, it hasn't been touched, was wondering if that backfire had something to do with it
