Online: Stuart
Anyone having problems with slipping handlebars?Here's our new product...
    5 years ago
    Been keen for those!  Must be lovely to have the luxury of a knurled spot on the bars too.
    SO.... Will these work on a set of bars with no Knurling?  (ie like mine)
  • blueystar
    blueystar
    5 years ago
    Quote source removed.
    some sandpaper from bunnings will do the same thing
    5 years ago
    A old push bike tube cut to shape used to do it for me.
  • Baloffski
    Baloffski
    5 years ago
    Unc,
    am with you as know what your talking, design, is a working model.
    Cheers. B.
    5 years ago
    Not cheap (but not skyhigh like some of the wanky brands).
    Purchased from Italy as they are the only crowd making them.  Agree they could do with Knurling as thats sloppy, but I indexed them with a pin in the end.  Next set (I bought 2 sets) will be narrowed and welded to the risers.
  • Birtyyy
    Birtyyy
    5 years ago
    I always had that problem with my old sporty. My solution was 13" risers and drag bars. This looks like a good option though.
  • robnicko
    robnicko
    5 years ago
    Quoting paulybronco on 18 Jun 2020 09:31 PM
    exactly what i was thinking
    5 years ago
    Paulybronco your idea was somewhat interesting (I bet you wouldn't do it again if you don't have to),
    but I can't picture how you manage to cut down an old push bike tube to solve the problem...
    The answer is very simple.....i use scisssors! . And its not retricted to a pushbike tube you can use any pnematic rubber tube.
    5 years ago
    so far with the 2003 sporty zero problem, I don't think over the years I have had that problem using stock Harley bars & clamps.
    a mate that had a springer Evo softail, that had ape hangers, had that problem all the time, so drilled small hole & put an Allen head through the bar & clamp. stopped it slipping!!
    I like your bars too Tussuck!
  • blueystar
    blueystar
    5 years ago
    sound like you have not tried sound paper maybe you should try it before mouthing off be working fine for me for years you will need scissors to cut
  • beaglebasher
    beaglebasher
    5 years ago
    What are these magnificent little gadgets manufactured from mate?
    The ones with the high tensile strength and the high compression ratio? (It says that in the video clip)
    You have obviously put the said little gadgets through a rigorous research and development and testing program but if you  had just asked on the forum  we could have saved you the trouble.
    Emery tape works in all conditions,  rain hail or shine. Always has, always will.
    Just out of curiosity,  how much are you charging for these gadgets?
    5 years ago
    that's not a 48 pinhead mate, just bits and pieces ! not having a go at you just stating a fact.
  • beaglebasher
    beaglebasher
    5 years ago
    Why did you join this forum  unc?
    To  establish a relationship with hopefully some new customers and maybe sell some of your amazing little gadgets?
    How is that working out ?
    Or did you join because you were getting bored with being speedy  / 103  etc?
  • steelo
    steelo
    5 years ago
    Come on BB. Be nice. UC has nothing to do with those 2 identities. He's been with us for a while. Not everything is a conspiracy. Even you are finding your way with the different types of personalities on the forum. He is a legitimate product distributor and made a small mistake with his wording and appreciation of "sandpaper".
  • beaglebasher
    beaglebasher
    5 years ago
    You absolutely sure about that steelo?
    Why has he deleted all his posts?
    Smells fishy to me.
  • Uncle Chougs
    Uncle Chougs
    5 years ago
    Quoting beaglebasher on 21 Jun 2020 07:11 AM
    Smells fishy to me.
    All good BB hope you didn't miss me too much! I'm back now!
  • Uncle Chougs
    Uncle Chougs
    5 years ago
    Let's put the video back shall we...
    Just cleaned up the non sense...Now let's clarifie this... I am "Only" presenting a new and easy to install product that you could store in you wallet..just in case.
    If any other contraptions works for you that's great!
  • beaglebasher
    beaglebasher
    5 years ago
    I apologise for the misunderstanding UC
    Good luck with it.
  • Uncle Chougs
    Uncle Chougs
    5 years ago
    Quoting beaglebasher on 21 Jun 2020 09:46 AM
    Good luck with it.
    No worries BB,all good! Thanks!
  • Uncle Chougs
    Uncle Chougs
    5 years ago
    Thanks Magnum!
    I thought it looked very cool the way I did it but got some issues with the"Men in blue"at times ...apparently the bike was"too loud"...
    Definitely didn't need a horn LOL!If anyone is "musically inclined"Panhead  engines sounds really nice(but also like the big Flatties)...
    I'm trying to negotiate a 65 Engine from one of my mates for another old school project (can't tell the missues atm LOL)...will share the build
    eventually...
    Thanks for your input!
