Online: tussuck, speedzter
Information About Corona
  • dicko
    dicko
    5 years ago
    Below is some information passed to me by freinds.
    I thought I should share.
    From John's Hopkins Hospital
    Hope this info sheds more light on this serious health issue.........Good information.
    "Stay Well and Be Safe"
      This virus is not a living organism . It is a protein molecule (RNA or DNA) covered by a protective layer of lipid (fat), which, when absorbed by the cells of the ocular (eyes), nasal (nose) or buccal mucosa (mouth), changes their genetic code (mutates) and converts into aggressor and multiplier cells.
      * Since the virus is not a living organism, but is a protein molecule, it cannot be killed. It has to decay on its own. The disintegration time depends on the temperature, humidity and type of material where it lies.
      * The virus is very fragile; the only thing that protects it is a thin outer layer of fat and that is the reason why soap or detergent is the best weapon. The foam CUTS THE FAT (that is why you have to scrub for 20 seconds or more, to create lots of foam).
    By dissolving the fat layer, the protein molecule disperses and breaks down.
      * HEAT melts fat; this is why it is necessary to use water above 77 degrees for hand washing, laundry and cleaning surfaces. In addition, hot water makes more foam, making it more effective.
      * Alcohol or any mixture with alcohol over 65% DISSOLVES ALL FAT, especially the external lipid layer of the virus.
      * Any solution with 1 part bleach and 5 parts water directly dissolves the protein, breaking it down from the inside.
      * Oxygenated water increases the effectiveness of soap, alcohol and chlorine, because peroxide dissolves the virus protein. However, because you have to use it in its pure form, it can damage your skin.
      * NO BACTERICIDE OR ANTIBIOTIC WILL WORK because the virus is not a living organism like bacteria; antibodies cannot kill what is not alive.
       * The virus molecules remain very stable at colder temperatures, including air conditioning in houses and cars. They also need moisture and darkness to stay stable. Therefore, dehumidified, dry, warm and bright environments will degrade the virus faster.
      * UV LIGHT on any object that may contain the virus breaks down the protein. Be careful, it also breaks down collagen (which is protein) in the skin.
      * The virus CANNOT go through healthy skin.
      * Vinegar is NOT useful because it does not break down the protective layer of fat.
      * NO SPIRITS, NOR VODKA, serve. The strongest vodka is only 40% alcohol, and you need a minimum of 65%.
      * LISTERINE is 65% alcohol.
      * The more confined the space, the higher the concentration of the virus there can be. The more open or naturally ventilated, the less.
      * You have to wash your hands before and after touching any commonly used surfaces such as : mucosa (mouth area) , food, locks, knobs, switches, remotes, cell phones, watches, computers, desks etc. and don’t forget when you use the bathroom.
      * You have to MOISTURIZE YOUR HANDS due to frequent washing. Dry hands have cracks and the molecules can hide in the micro cracks The thicker the moisturizer, the better.
      * Also keep your NAILS SHORT so that the virus does not hide there.
    5 years ago
    thanks dicko, we need to get back to work!
    Also with this info only form of transport is a MC !!
    Also on new's was something about Tas playing games with the numbers.
  • gidgi
    gidgi
    5 years ago
    Some interesting points I didn`t know
  • beaglebasher
    beaglebasher
    5 years ago
    Thanks for that dicko.
    Youve just gave me a head fuck.  I thought a virus was a tiny animal of some description.
    I bet all the best scientists in the world are getting a headfuck
  • steelo
    steelo
    5 years ago
    Beware of "friends" sending helpful health information This list is sometime false, exaggerated or at best misleading. Johns Hopkins have said that the information was not from them. Fact Check
    5 years ago
    Quoting steelo on 10 Jun 2020 11:02 AMedited: 10 Jun 2020 11:20 AM
    But if its on Facebook it must be real!
  • dicko
    dicko
    5 years ago
    Thanks for the fact check , Steelo, At least enough of it is true or mostly true, to get the point across wash your hands etc.
    I guess most people imagined a living organism but it is clearly not so.
  • beaglebasher
    beaglebasher
    5 years ago
    So what is a virus dicko?  I googled it last night and have forgot already.
    What is a virus?  In layman terms.
  • dicko
    dicko
    5 years ago
    Quoting beaglebasher on 11 Jun 2020 10:32 AM
    A virus is an infective agent that typically consists of a NUCLEAIC ACID molecule in a protein coat, is too small to be seen by light microscopy, and is able to multiply only within the living cells of a host. hence the terms DNA RNA etc Rybonucleaic acid and Dynorybonucleaic acid. (Dunno if I spelt right)
    It is not a living organism, and therefore cannot be killed ( but can be washed away before it infects ) so once  infected a antidote is required . Or complete isolation to prevent spread, and allow it to get to zero hosts.
    I like you once thought of it as a little wriggly worm or something.
    There ya go ,you are now a scientist equipped with unlimited knowledge.
  • bloodog
    bloodog
    5 years ago
    Quoting dicko on 12 Jun 2020 12:56 AM
    Just up grade me skill level from a dum plasterer
  • Grease Monkey
    Grease Monkey
    5 years ago
    Remarkable that drinking bleach doesn't work aye!
  • beaglebasher
    beaglebasher
    5 years ago
    Thanks again dicko. I read your post a couple of times but I am still having trouble getting my head around it.
    A virus is a weird thing.
  • Baloffski
    Baloffski
    5 years ago
    WTF.............
    Have I missed something here?
    I thought there was a line on this virus we had going.
    I cant find it, but I'm dumb illiterate, with no empathy or tolerance.
    I was the most empathetic man in Victoria, then, I lost my job, shortly I am selling my Harley , then I may sell my house.
    Am in Victoria, have to go through three road blocks to see a specialis,( Back injury from writing off three motorcycles, and rolling through the air like an apple core out the window)
    Covert 19 has fucked me, walk in my shoes and you would know S.
  • Mr.Mow
    Mr.Mow
    5 years ago
    I just saw Carona as a little dude who just wants to get intimate.
  • WideglidingNZ
    WideglidingNZ
    5 years ago
    Quoting Baloffski on 14 Jul 2020 02:00 PM
    WTF.............
    I'm terrible sorry to hear this Baloffski this virus is fucking up loads of people & business's, Actually I feel for everyone affected/infected with this cunt of a virus, We are lucky in NZ but I don't think we have seen the end of it yet, As people (fuck tards) are breaking out of our border isolation hotels quite regularly
