Online: speedzter
Axle alignment plug set
  • micathia
    micathia
    5 years ago
    The part number is HD-48856-A
    This is on 2016 Dyna service manual but Stealer doesn't have it at all.
    Anyone got this before?
    thx
  • imoo6170
    imoo6170
    5 years ago
    Never heard of it but a quick search on one of the American forums came up with the following comments:
    - There should be a hole in the swing arm 2-3 inches forward of the axle head/nut. That's where you take your measurement from. Use a bent and sharpened piece of rod, like a coat hanger. Or use a caliper and measure to the center of the axle, both ends. Cheap and easy.
    - Bent piece of brazing rod and a zip-tie... works like a charm.
  • brucefxdl
    brucefxdl
    5 years ago
    Quoting imoo6170 on 09 Jun 2020 06:32 AM
    the one i made is similar,only the short side is straight with a slight point. the rod i used fits the swing arm hole neatly. easy to use with small o rings to slide along to compare to each side with the centre hole in the axle.
  • micathia
    micathia
    5 years ago
    found it. here
    https://www.hdforums.com/forum/dyna-parts/1023077-hd-48856-5a-axle-alignment-plugs.html
    gee the price WTF.
    Harley Heaven in Melbourne doesn't sell them.
  • Far Canal
    Far Canal
    5 years ago
    Quoting micathia on 09 Jun 2020 07:57 AM
    found it. here
    gee the price WTF.
    Bruce is on the money, micathia.
    If you can't make your own tool to do the job then I am struggling to imagine how you could make a sandwich.
    5 years ago
    found it. here
    gee the price WTF.
    Quoting Far Canal on 09 Jun 2020 08:46 AM
     Have you considered that he may be anorexic before you made your comment ...LOL
  • robots
    robots
    5 years ago
    i made some on the lathe
    if you go to a mens shed someone will make you some up
  • Far Canal
    Far Canal
    5 years ago
    Quoting robots on 09 Jun 2020 10:14 AM
    On a lathe?.
    I'm speechless.
    Surely you could make that tool using a cable tie, a coathanger and your Irish calculators that would do the job.
  • robots
    robots
    5 years ago
    Yeah the plugs
  • Far Canal
    Far Canal
    5 years ago
    Quoting robots on 09 Jun 2020 12:59 PM
    Yeah the plugs
    Ok, fair enough.
    I was referring more to the picture from a couple of replies ago of the brazing rod etc.
    5 years ago
    The specs and shape are in the harley workshop manual..... (well for my old FXR it is).
  • micathia
    micathia
    5 years ago
    Quoting tussuck on 09 Jun 2020 09:57 PMedited: 09 Jun 2020 10:01 PM
    dyna has a hole on swingarm, it only needs a 10cm long L shape tool to do the job.
  • micathia
    micathia
    5 years ago
  • wadewilson
    wadewilson
    5 years ago
    Robots, I must be missing something here, I spent all night in the workshop and still cannot make a sandwich on the lathe...
    Best I got was a ham splatter up the wall!
    Wade
    5 years ago
    Quoting micathia on 10 Jun 2020 10:33 PM
    So does the FXR... The small hole in the swingarm bolt is behind a cover plate and the shape is so it fits past factory pipes etc.
    5 years ago
    This whole thing is being over thought...lol
