L/H switch block
L/H switch block
Pedro123
5 years ago
Hi All,
Looking for a L/H switch block for a project. (Hi/Lo switch worn out on the one I have).
Has Hi/Lo, horn and L/R indicator switches in the same assembly.
Have searched flea bay and only come up with 7/8" or 22 mm switches, unless they have the late model turn signal on both sides.
Would consider a dual sided rocker switch for the lights and wire it in separately.
Any ideas or info would be greatly appreciated.
Cheers Pedro
