Online: Stuart
Bobtail Rear Fender On 06 Street Bob
  • RaggedHaggis
    RaggedHaggis
    5 years ago
    Ok I’m probably going to get hammered for this! Ive got an 06 dyna street bob and I’m looking to get the fat bob, wide glide tail fender look. I’ve searched eBay, and numerous Aussie sites with no luck. Could someone who has done this mod or know of point me in the right direction.cheers
    5 years ago
    Looks to be a piece of piss fender swap.  Just buy an new fender and go for it.
  • Far Canal
    Far Canal
    5 years ago
    And fender support brackets.
    Easyr may well have both.
    5 years ago
    What are you gonna do with the full rear fender you have and where are you?
  • RaggedHaggis
    RaggedHaggis
    5 years ago
    Hey all thanks for reply’s. I’ve checked out everything on easyr but nothing pertaining to the 2006 fxdbi. I just thought if someone on here has done the swap over could they let us know of specific parts. I believe some fat bobs & wide glide rear fenders are slightly wider. I can’t be stuffed ordering a bunch of wrong parts and then having to send them back again. Cheers
  • RaggedHaggis
    RaggedHaggis
    5 years ago
    Quoting fatbat on 07 Jun 2020 07:36 AM
    Yeah not sure on that one yet, I’ll see how far I get with it first.
  • K. Lindberg
    K. Lindberg
    5 years ago
    First post. Be gentle… :-)
    A riding buddy did go the other way, from Ductail (FXDWG) to Superglide/Street Bob.
    You would need the fender with rear light (obviosly), and the FXDWG fender struts since they are longer compared to the ones You have.
    He also had to change seat as the Wide glide seat was a bit longer. Do not know if this applies to Your Model year though.
    If You are worried about the width of the rear fender, I would suggest You measure the width between your fender struts, or rather the width of the rear subframe contra the width of the new fender.
    As for the rear indicators I think the OEM wide glide indicators together with their stalks looks best, but any indicators could be modified to fit.
    Cheers. /Lindberg
  • RaggedHaggis
    RaggedHaggis
    5 years ago
    Hey thanks for the reply much appreciated. Never would have thought of the seat. Much for me to digest. Cheers
  • Half
    Half
    5 years ago
    i have done the opposite swap, the fxdwg rear gurd is wider in the rear where the guard mounts, so i had to use spacers for my fxdl guard swap.
    there was a HD oem kit (59925-06) that is the right width for fxd/c/l/b, so its actually in thinner size to suit that frame width
    as other have said i needed new tail light/mounts/bolts, both the rear indicator stems/wiring/bolts, fender struts etcc, in my case i also needed new wiring that sits under the (3m stickypads) rear guard.
    Change the look and the attitude of your Dyna motorcycle with a Bobtail Rear Fender. Standard on the Dyna Wide Glide® model. This sleek upturned fender adds style to the rear of your bike.
    Fits '06-later FXD, FXDC, FXDL,'14-later FXDF and '06-'08 FXDB models.
    FXDF requires separate purchase of tail light assembly,
    Stock on '06-'08 FXDWG models. Does not fit '08-'13 FXDF, FXDFSE/2,
    '10-later FLD and FXDWG models.
    Requires separate purchase of Installation Kit P/N 69710-06
    Primed.
