Baffles - Where to get
5 years ago
Hi,
Building a set of up-swept fishtails for the Sporty and am not really interesting in being pinged every 10min for noise so will install some baffles.
Anyone have a set of 'something' that will fit into 1 3/4" pipe or can point me in the right direction to buy some?
5 years ago
If you’re happy buying from overseas have a look at dk customs offerings. Reasonable and effective options there for in header solutions
dicko
5 years ago
I think i saw some on EASY R under exhausts
Mr.Mow
5 years ago
Quoting tussuck on 06 Jun 2020 02:50 AM
Hi,
1 3/4” baffles can be found on eBay for about $15, cheap little metal jobs.
There’s a ton of different designs, some work better than others, some will choke your bike to the point of barely working.
I’ve also tried the expensive big brand ones and honestly I don’t think they’re any better.
5 years ago
Thanks guys,
I checked out Easy R last night and they have a chit load of baffles so Im sure I can find a nice quiet one there. Way easier too given they are local.
Here is my COVID Project (nice to be able to lay the bike up for a few weeks in the shed)
Working on the rear supports for the upswept ends now and then the fish tails.
imoo6170
5 years ago
Quoting tussuck on 07 Jun 2020 02:59 AM
edited: 07 Jun 2020 03:00 AM
Thanks guys,
You may want to check out MCAS as well - they are also around Melb as well
https://www.mcas.com.au/shop/category/custom-exhaust-baffles-heatwraps-packing
Suggest you give your local store a ring to see what they have in stock - I have noticed a bit of a difference in the stock held by the various Sydney stores
