Online: Merv
stainless pipes
  • micathia
    micathia
    5 years ago
    Hi
    Just asking, what is the pro/cons of stainless pipes?
    Does it turn into nasty colour with age?
  • John.R
    John.R
    5 years ago
    Much much lighter.
  • wello
    wello
    5 years ago
    Quoting John.R on 03 Jun 2020 12:49 PM
    Much much lighter.
    than what ?
    5 years ago
    Much much lighter.
    Quoting wello on 03 Jun 2020 12:58 PM
    than what ?
    Lead pipes!
    5 years ago
    I have had stainless pipes on Harleys, & had them crack. You don’t have to worry about discolouring as you can hand polish ( lot of rubbing ). They sound different too. They were lighter than the D&D 2 into 1 race system I replaced them with. The D&D was built to last!
  • John.R
    John.R
    5 years ago
    Much much lighter.
    than what ?
    What do you reckon? What other material are you using for pipes?
  • John.R
    John.R
    5 years ago
    Quoting Krash Kinkade on 03 Jun 2020 10:09 PM
    Yeah they definitely aren't as springy as mild steel, so if the mounts aren't A1, the stainless can fatigue and crack. Especially with cheap light guage Chinese stainless and robot welds.
    I luckily haven't had any issues with ones I've made myself and they get absolutely flogged from wheelies.
  • RossW
    RossW
    5 years ago
    Quoting micathia on 03 Jun 2020 10:21 AM
    Hi
    They don't rust.
    They don't rust
    They don't rust
    If they are not double skinned, they will go blue from heat near the heads. Some people like the look.
  • wello
    wello
    5 years ago
    Much much lighter.
    than what ?
    Quoting John.R on 03 Jun 2020 11:02 PMedited: 03 Jun 2020 11:03 PM
    generaly mild/carbon steel .. however the weight difference is next to nothing unless the gauge is different
  • micathia
    micathia
    5 years ago
    Thx for the input. I have decided to pass the stainless.
    In case you are interested:
    https://www.easyr.com.au/vance-hines-stainless-hi-output-2-1-dyna-06-15-exc
    big discount!!!
  • Birtyyy
    Birtyyy
    5 years ago
    Quoting micathia on 04 Jun 2020 04:44 AM
    big discount!!!
    Still seems expensive. You could get a TBR, Bassani or Fab28 exhaust for that money
    5 years ago
    big discount!!!
    Quoting Birtyyy on 04 Jun 2020 05:44 AM
    OMG.....Ugly as chit and overpriced to boot.  AND your right, they are not even a real pipe per-sec compared to Bassani or S&S.
  • Retroman
    5 years ago
    My only personal experience of stainless pipes on a motorcycle was a "Gazelle" 4 into 1 system I bought for a 1976 Kawasaki z900 around 1984.
    Made in South Africa , it was well shaped and sounded good , curved around the underslung oil filter.
    So you did not need to take the system off to service the oil filter and sump plug. ( Some other brands at the time fouled the oil filter access )
    The downpipes "blued" almost instantly , single skinned. The stock OEM z900 downpipes were double skinned chromed. That was a wee bit "fugly"
