Online: Merv
Where to get Clutch plates
  • Pagey
    Pagey
    5 years ago
    Does anyone know where I can get hold of some replacement 2016 883 clutch steel and friction plates. I want to swap out the spring plate
  • Pagey
    Pagey
    5 years ago
    Picked up the replacement plates from Harley Heaven today. Thanks
  • Pagey
    Pagey
    5 years ago
    Installing the Hammer 1250 kit so needed to upgrade the clutch spring and get rid of the grenade plate before it exploded
    5 years ago
    What’s the difference between the hammer 1250 performance kit and the oem harley 1200? Compression, cams, head work?
    5 years ago
    Quoting Pagey on 04 Jun 2020 09:17 AM
    I don’t mind a bit of clutch slip, it takes shock load off other parts, & in most cases does not hurt performance ( in the real world.)
    If you put them in 5th gear & open them up aggressively & the clutch slips, you could remove spring plate & leave stock diaphragm spring , add an extra plate, that will stop it slipping & you will still have same feel as stock ( pull effort ) I like the SE extra plate kit I’m useing but I did not use the spring that came with it I just use the stock 2003 1200 (74cid ) spring.
    I notice it’s a bit savage off the line, with spring plate they give a bit, without they hook up a bit harder. Like with my bike stock 1200 gearing &:off idle on lights drop clutch no rev’s then open throttle , it jumps out the hole hard (scares me sometimes) & it pulls 2,500 rev top gear hard like an electric motor ( I love that )
