Online: speedzter
Wiring on a 2012 road glide
  • Ballsy
    Ballsy
    5 years ago
    G,day all,
    I,ve got a bit of a problem and want to run it past forum members to see what they recon.
    Bought a road glide a few years ago and decided to tow a trailer which has been fitted out as a camper, so all has been good until on a ride with a few mates they noticed that my indicators stopped working properly, still had parkers and stop lights but no blinkers, up until this happened they were working for years, I thought probably a broken wire so started searching, then it dawned on me that when you turned off the bike the alarm sounds and the blinkers flash so what the fuck could it be I thought, when I put the tow bar I bought a trailer wiring loom with the load being put on the battery and not the bikes wiring,got me stumped, I've followed all the wiring and it looks ok, trouble is I sit down with a carton and end up shit faced and pissed off, can anyone give me a bit of advice on what to check next, probably with a couple of 6 packs instead of a carton.
    Cheers Ballsy
  • Roo Ted
    Roo Ted
    5 years ago
    Ballsy,
    I did a job on a mates Fatboy a while back, it's about the same age as your bike.  Worth a look under the rear guard. The wiring loom to the tail lights & indicators is double sided taped to the underside of the guard. Over time his wiring sagged and intermittently touched the tire, particularly two up. The insulation wore down & eventually he had shorts between the wiring which caused intermittent electrical faults. Ultimately he got run up the arse by a mate who didn't see the brake light come on as they approached an intersection.
    Might be worth checking the trailer loom too. It might have rubbed or taken a nick during installation.
    Pull the plugs to the rear electrics & give 'em a squirt of CRC or something similar while you're there.
    My bet is it's something simple. Good luck.
    Oh, and drink beer After the job's finished. ;-)
    5 years ago
    Yah need a manual...everything else is pure guess work.
  • dicko
    dicko
    5 years ago
    Maybe you have a mix of LED"S and bulbs???? Like bulbs on trailer and leds on bike ?? you might need a different relay ,or all led's, or fit a load inline with led's. Just guessing  without all information.
  • Ballsy
    Ballsy
    5 years ago
    Quoting dicko on 08 Jun 2020 04:01 AM
    Hey Dicko
    its all LED,s and it did work for a years, got me stuffed, I think it might have to go to Perth
  • Ballsy
    Ballsy
    5 years ago
    Quoting Roo Ted on 08 Jun 2020 12:48 AMedited: 08 Jun 2020 12:51 AM
    Ballsy,
    Hey Roo,
    Ive got a Fatboy low as well so checked out the wiring you talked about, looks good on the road glide , I did the crc in every plug I could find and have tried the trailer on and off , thanks anyway mate, I,m going to have a beer fuck it.
  • Ballsy
    Ballsy
    5 years ago
    Quoting tussuck on 08 Jun 2020 02:58 AM
    Hey Tussuck,
    I,m thinking your right but its easier to ride the fucker up to Perth and get them to fix it,
  • Roo Ted
    Roo Ted
    5 years ago
    A shame you weren't a bit further south Ballsy, I could have taken a look.
