Exhaust tube end expander
5 years ago
Hi,
Need to expand the end of a 1 3/4 " tube so i can make a set of slipon tail pipes. Has any one used this tool for the job or is there a better way?
meanmother57
5 years ago
Exhaust shop
Rivo
5 years ago
Make sure you dont just try and expand the pipe without annealing it first, otherwise it will probable split the tube.
