suspension
suspension
stephen
5 years ago
Just wondering if anyone has an idea what the hell is going on with my bike .When i hit the front brake going slow or up to 20 k there is this tapping sound which i thought was the front suspension, so i took the bike to stevos in dandy and they said it might have been a spring that had broken so i took the bike to suspensions r us in seaford and izzy replaced front springs and changed the the valves and while i was there put new yss suspension on the back , on the way home the bloody same tapping from the front i couldn,t believe it now i have a feeling it cant be the suspension can anyone have a rough guess what it might be. all i know is when the front dives a bit when braking the noise happens
steelo
5 years ago
Just did a google search. Couple options. Do you have floating rotors?
stephen
5 years ago
Not sure what that means steelo
beaglebasher
5 years ago
You might need to give us more information mate.
What model? What year? ABS brakes?
stephen
5 years ago
Grease Monkey
5 years ago
Beautiful bike mate, love that model.
Grease Monkey
5 years ago
As to the tapping, the floating rotor(that's what is on your bike), as steelo mentioned already, can cause a noise like you describe if there is something amiss, usually it's more a clicking sort of a sound sometimes with a shuddering feeling, could be loose on the rivets, friction surface warped, bulges around the drilled holes etc.
Check the pads are not loose in the caliper and damper plates are ok.
Somewhat to start anyway.
stephen
5 years ago
Thanks a million gives me somewhere to start, I will let you know the outcome
78gold
5 years ago
Can you feel it through the bars.??
Might be steering head bearings??
Put it up on a stand and check for movement.
5 years ago
Quoting 78gold on 23 Jun 2020 05:44 PM
I was thinking same thing.
Ride over speed humps, without using the brake, if you hear and feel a knock, could be loose steering head bearing. but test that first, if it's that I can tell you how to fix.
