Grey import
  • MJ
    MJ
    5 years ago
    Hi got a 2012 grey import
    Anyone able to tell me what’s needed to get the brake and blinkers to work indepent of each other
  • STEAMER
    STEAMER
    5 years ago
    What you want to change them to old style for.?
      Not sure there is a plug in adaptor. Might need to cut wires and rewire how you want it. Jaycar should have plugs to make own set up
  • MJ
    MJ
    5 years ago
    It has red only on back for blinkers and brakes it’s a weird setup
  • STEAMER
    STEAMER
    5 years ago
    Can the lenses only, be changed, or if not, then change whole light to Australia. Adr compliant.   Yankee even use red as indicators on cars.
     There was a guy selling  all four indicators, including 3 in one for rear, $150.
    On a facebook harley page.
    Will look for them now.
    This way should be plug n play
    https://m.facebook.com/groups/129344234077248?refid=18&ref=bookmarks&_ft_=qid.6831370981124388471%3Amf_story_key.1180330845645243%3Agroup_id.129344234077248%3Atop_level_post_id.1180330845645243%3Atl_objid.1180330845645243%3Acontent_owner_id_new.100012163234246%3Acommerce_rank_obj.%7B%22viewer_id%22%3A1145093300%2C%22target_id%22%3A2942487569203401%2C%22target_type%22%3A0%2C%22primary_position%22%3A14%2C%22secondary_position%22%3A0%2C%22search_query%22%3A%22%22%2C%22search_sid%22%3A%22%22%2C%22session_id%22%3A0%2C%22typeahead_sid%22%3A%22%22%2C%22ranking_signature%22%3A5142022431408099701%2C%22commerce_channel%22%3A103%2C%22commerce_type%22%3A2%2C%22ectr%22%3A0%2C%22value%22%3A0.26972764892656%2C%22original_value%22%3A0%2C%22model_scores%22%3A%7B%7D%2C%22upsell_candidate_ids%22%3A%5B%5D%2C%22upsell_type%22%3Anull%2C%22metadata%22%3A%7B%7D%2C%22ad_imp_delivery_data_binary%22%3Anull%2C%22ad_imp_delivery_data_array%22%3Anull%2C%22qp_renderer_type%22%3Anull%2C%22top_unit_ranking_score%22%3Anull%2C%22is_budget_upsell%22%3Afalse%2C%22is_pacer_applied%22%3Afalse%2C%22is_billboard_promotion_upsell%22%3Afalse%2C%22category_id%22%3Anull%2C%22candidate_score_map%22%3Anull%2C%22candidate_signature_map%22%3Anull%2C%22vertical%22%3Anull%2C%22vertical_metadata%22%3Anull%2C%22collection_id%22%3Anull%2C%22theme_id%22%3Anull%7D%3Asrc.22%3Aphoto_id.994473224301443%3Astory_location.6%3Astory_attachment_style.group_sell_product_item%3Afilter.GroupRankedFeedEntQuery&__tn__=C-R
  • MJ
    MJ
    5 years ago
    Because it is a American bike imported to Australia, the blinker Parker’s and brake are all one light. There is no separation between them. So I need to get new light system for the rear that has red for Parker and brake an yellow for indicator.
  • MJ
    MJ
    5 years ago
    Ok I think I have it sussed I though it was a single Filament globe but there are two so I may be able to do it
  • Retroman
    5 years ago
    This is one of the many things that have to be done for "Australian compliance"
    US bikes and cars can have red rear indicators. Australian bikes (and cars) have to be amber.
    Through the RAWS system this is just one of quite a few changes
    UNLESS the bike is a private/personal import of a bike you have owned abroad for a period of time.
    You still need amber indicators to pass the pits in any Australian state.
    Depending on the model it is done in different ways. Some of the later bikes have no separate taillight brakelight all lights are in the indicators.
    On my own "grey import" a 2008 CVO Softail , it had an LED stop/taillight as stock OEM and amber indicators , came from Texas so no dramas.
    I imagine you are talking about a Breakout type setup ? What model is it you did not elaborate ?
  • MJ
    MJ
    5 years ago
    It is a 12 streetglide
    I’m waiting on a new rear assembly to turn up. I will use a dropping resistor to run the park lights, tie  the the brake lights together then run two new wires then blinkers as standard
