Online: Stuart
remove battery cover band
  • micathia
    micathia
    5 years ago
    hi
    how can i remove the chrome battery cover band?
    it looks,like only has two knob things on the back. not screws?
    hammer?
  • Soapbox2627
    Soapbox2627
    5 years ago
    dremel them of flush, then drill them out, couple fancy bolt heads to fill the holes
    Hammer??
  • Far Canal
    Far Canal
    5 years ago
    Quoting Soapbox2627 on 23 May 2020 08:21 AM
    Hammer??
    Hammer!
    Bloodog on this forum is the man to ask, think his weapon of choice is the claw hammer.
  • Benno
    Benno
    5 years ago
    Quoting micathia on 23 May 2020 03:05 AM
    hi
    hammer?
    Be aware, the little plastic knobs aren’t the only thing holding it on, there is adhesive tape in multiple places also. I had a bland corrugated aluminium trim on mine, absolutely destroyed It trying to get it off, I put the one with the wide glide script on, it comes with the adhesive but not the little black piece of plastic with the knobs on it, it hasn’t flown off.
  • Mr.Mow
    Mr.Mow
    5 years ago
    You can just buy a plain black one from HD, think mine was $30?
  • wello
    wello
    5 years ago
    hi
    hammer?
    are you just trying to de-chrome it .. why not just spray it black first and see how it looks before u destroy it ?
  • Ratbob
    Ratbob
    5 years ago
    hi
    hammer?
    Quoting wello on 24 May 2020 04:22 AMedited: 24 May 2020 11:59 AM
    Good idea cause it ain’t pretty underneath.
