Plug n play speedo for fxst
Mr.Mow
5 years ago
So the sticking point I have with fitting my peanut tank to my 2005 fxst is what to do with the speedo.
From what I understand the sensor feeds from the gearbox, so theoretically there should be a drop in plug n play speedo, I’m going to mount a small gauge off the engine brace on the left.
Anyone know anything about this? Local bike shops won’t touch it, digging around online brings up very little.
DocGreen
5 years ago
Mr Mow, have you had a look at the Dakota Digital range? Think Rollies is a seller.
DocGreen
