Online: frostbite
Lo Range
  • markmckenz
    markmckenz
    5 years ago
    I was driving home tonight, I knew there was something wrong with the bike as like when you can ‘just tell’. The Lo Range text then appeared on the speedo, coupled with the flashing fuel light and the steady red light.
    At the same time the fuel gauge went from ½ tank to EMPTY!! I filled her up to be sure in case I was leaking fuel and I was corrrect.. $8! So it definately didnt need fuel it and its still displaying it now.
    Any suggestions?
  • wello
    wello
    5 years ago
    Quoting markmckenz on 22 May 2020 01:53 PMedited: 22 May 2020 10:47 PM
    Any suggestions?
    quite possibly the battery or a connection .. dirty or loose etc
    check out this site .
    https://www.hdforums.com/forum/softail-models/1128431-im-getting-a-lo-rng-signal-help.html
  • beaglebasher
    beaglebasher
    5 years ago
    Turn the ignition off for one minute.
    Or two..
    Should sort itself out.
