Online: speedzter
2018 Streetglide run brake light not working 1 side
  • Lucky09
    Lucky09
    5 years ago
    Hi all
    Having problems with 2018 streetglide rear light
    Seeled led unit.
    Run light left side is dull when ignition is turned on , right side is normal , pull brake lever or rear brake foot lever dull side goes out completely right side works normally.
    Indicators work fine.
    Turn ignition off try again same thing.
    Pulled plugs to tri bar and all looks normal no corrosion, traced back wiring to plug under seat no damage of any kind visable..
    Thinking 1 side of led is cooked .
    Any info appreciated.
  • potluk
    potluk
    5 years ago
    swap the lights over under the seat see if the problem swaps sides if so maybe a pinched wire
  • Lucky09
    Lucky09
    5 years ago
    Quoting potluk on 16 May 2020 08:23 AMedited: 16 May 2020 08:24 AM
    Thanks for the reply mate but as suspected one side fried .
    Under warranty so new one coming
