Online: speedzter
Laser wheel alignment
  • micathia
    micathia
    5 years ago
    Hi
    Just asking, anyone know a good shop that can do wheel alignment with laser tools?
    Melbourne area, I live in north eastern suburb.
    thx
    5 years ago
    Quoting micathia on 15 May 2020 10:10 AM
    Hi
    thx
    Why do you think you need laser alignment?
  • Ratbob
    Ratbob
    5 years ago
    Been using string for years, not sure a laser would be useably more accurate.
  • micathia
    micathia
    5 years ago
    Hi
    thx
    Quoting paulybronco on 15 May 2020 10:26 AM
    I just did a string alignment by my local shop,
    before alignment:
    my bike lean towards right, fuel tank not pointing straightforward and bit hard to stick to straight line;
    after alignment:
    easier to stick to straight line but lean further towards right, fuel tank still not pointing to straightforward.
    I don't know what 's wrong with it.
  • Ratbob
    Ratbob
    5 years ago
    What bike, does it have a 240 rear?
  • micathia
    micathia
    5 years ago
    Quoting Ratbob on 15 May 2020 12:31 PM
    21" 90mm front and 180mm rear. wide glide
  • wello
    wello
    5 years ago
    front forks out ?
  • Grease Monkey
    Grease Monkey
    5 years ago
    Check the engine alignment mate, not hard to do with a service manual, rear swing arm is attached to the gearbox, engine is rubber mounted, shit can get queer if the mounts are dodgy or the top stabiliser is out of whack for whatever reason.
  • micathia
    micathia
    5 years ago
    hi thx for all the ideas.
    Here is the list,
    1. I have a third party fork bracer, it does help handling but could that cause problem?
    2. engine mount: the front rubber looks slightly wore, I will upload a photo later.
    3. fork: I do feel that the front wheel is not perfect vertical to triple tree, but I don't 100% trust my eyes.
    4. could weight distribution a problem? but every Harley is pretty much similar, right? how come some lean some don't? even the same model?
  • STEAMER
    STEAMER
    5 years ago
    When riding, keep in mind that the camber of roads in Australia will more than likely have tyres wear slightly more on right side.
       You might think some roads like freeways are dead flat, but they have very slight camber for water run off
  • micathia
    micathia
    5 years ago
    Quoting STEAMER on 15 May 2020 10:05 PMedited: 15 May 2020 10:06 PM
    yes I know this. 90% of chance the road is higher on the right and lower on the left. What puzzle me was, at that 10% camber is on the opposite directly where left is higher, the bike doesn't lean to left as same degree as it does to right.
  • beaglebasher
    beaglebasher
    5 years ago
    Try and take a few pictures of the bike mate. Stand it up as straight as possible and take a couple of pics front and rear.
  • micathia
    micathia
    5 years ago
    Quoting beaglebasher on 16 May 2020 12:27 AM
    I just spent the quality weekend morning, use a tailor tape to measure front and back, left and right of this bike in anyway I can think of. (Sadly), I found measurements are all symmetric, accurate into mm. Forks are at same length, front wheel is vertical to triple tree, etc.
    I confess my next try will be, taking the suggestion as seen in every similar thread like this.....put my wallet in my left pocket.
    Some other threads suggest the weight distribution is not symmetric. The primary is a big chunk on the left while many aftermarket pipes are lighter. Mine is not symmetric, but only by 1 or 2 degree, but I felt like 10 degrees leaning on the right all the time.
    I don't know what to do now. Other than put my wallet in my left pocket really.
  • wello
    wello
    5 years ago
    Quoting micathia on 15 May 2020 09:53 PMedited: 15 May 2020 09:54 PM
    Here is the list,
    #3 .. if u feel the wheel is out of vertical alignment then measure the top of wheel to side of fork on each side ..  i didnt think it could be out due to the spindle .. but thought maybe the forks are twisted.
    personally i would do a string check anyway .. do u have a jack stand ?
    also .. find someone with a dashcam and get them to follow you while you go for a ride  .. stay centre of road so direct with camera then u can study the footage , im pretty sure we cover this topic not so long ago on here and weights were used to balance the bike better .. just cant remember who it was
  • Far Canal
    Far Canal
    5 years ago
    Quoting micathia on 16 May 2020 01:51 AM
    "I don't know what to do now. Other than put my wallet in my left pocket really."
    Did you check what Grease Monkey suggested?
    Maybe you do not have a service manual. If you do not, and plan on keeping the bike, it would be worth getting one.
  • wello
    wello
    5 years ago
    sell the bike .. buy this .. sorted !!
    https://www.bikesales.com.au/bikes/details/2008-harley-davidson-rocker-c-96-fxcwc-my09/SSE-AD-6637944/?Cr=0&gts=SSE-AD-6637944&gtsSaleId=SSE-AD-6637944&gtsViewType=showcase&rankingType=showcase
  • micathia
    micathia
    5 years ago
    Quoting Far Canal on 16 May 2020 07:32 AMedited: 16 May 2020 07:33 AM
    yes, I am researching on that. thx. I am an IT pro, know nothing about mechanics tho.
  • Far Canal
    Far Canal
    5 years ago
    Fair enough.
    Just hope you have not bought a bike that his been in a ,"bingle, crash , etc" and has bent the frame. Unbeknown to you when you bought it.
  • micathia
    micathia
    5 years ago
    Quoting Far Canal on 16 May 2020 09:55 AM
    Fair enough.
    nah nah, I bought it from Stealer. We all trust stealer, don't we?
