Online: softfat, Merv
Price Advice
  • sneekypete
    sneekypete
    5 years ago
    I Have 2017 fatboy lo S with a 110 motor that I am about to get cams fitted I've had a quote and just im wondering what the labour  cost should be approximately
  • JFE
    JFE
    5 years ago
    Canberra HD and others are quoting $1699. May be worth a call to query the T&C’s ... will give you an additional starting point.
    https://www.canberraharley.com.au/local-offers/
  • Phatty
    Phatty
    5 years ago
    Quoting JFE on 11 May 2020 03:15 AM
    $1699.00 for labour.. Fuck Me.
  • Birtyyy
    Birtyyy
    5 years ago
    Quoting Phatty on 11 May 2020 05:05 AM
    No, that's parts and labour.
  • steelo
    steelo
    5 years ago
    My steady as she goes recommendation would be to not do it. You already have nearly 1900cc which is a fair bit. Unless you already have the tuner, I don’t think that and tune up will be included. So that could potentially take you over $2k.
    Save your money. Just enjoy the bike. No one has ever looked at any of my bikes and been disappointed that they weren’t stage 2. Good luck.
    5 years ago
    If it’s for parts, labour and dyno tune then that’s about what they charge
  • John.R
    John.R
    5 years ago
    I've got a 110 motor going into one of the bikes Im building, and my quick search around yielded very few options of cams for that motor that would be any good without an increase in compression.
    5 years ago
    Quoting John.R on 11 May 2020 09:49 PM
    That’s a really good point. Static compression on the factory 110 engine is around 9.2:1 and therefore suited to the se255 cam mated to it. What replacement cams were you considering? Most replacement cams will want higher compression to work their best. You’ll give up some low down torque by changing to just about any other cam unless you increase compression which is more dollars with either piston change or head shave.
    5 years ago
    Quoting fatbat on 11 May 2020 10:13 PM
    Or very cheap with a thinner head gasket to bump the comp. Again depends if that marginal increase will be enough for what your looking at to get the cam interested
    5 years ago
    Quoting paulybronco on 11 May 2020 11:14 PM
    Head gasket isn’t going to add much really. He might go from 9.2 to 9.3 and still have the same limited cam choice.
    5 years ago
    Quoting fatbat on 12 May 2020 06:47 AMedited: 12 May 2020 07:50 AM
    Absolutly. This may be of some use to folks
  • Mr.Mow
    Mr.Mow
    5 years ago
    Any time I’ve enquires about getting ‘bolt in’ cams I get hit with ‘oh you need to replace the pushrods too oh you have that tuner? No you’ll need to buy the xyz tuner blah blah’.
    Bill for ‘bolt in’ always ends up looking like $2k
