Cleaning oxidised S & S Blocks
Blocky
5 years ago
Gday Gents
Just picked up an old FXDWG with a 96 S&S that has a bit of oxidization on the blocks. Any tips on how to get them clean without pulling it down?
5 years ago
Autosol and elbow grease or 1200 grit wet and dry first if its bad and then Autosol.
Coat with a car ceramic coating afterwards to protect
There is no easy way...
Plan B is to remove and take to a pro polisher and hand over a few hundred to have them done perfect.
Blocky
5 years ago
Thanks Tussuck
I kinda figured there was no easy way, better fill the shed fridge and get into it.....
