Online: Ronmac, Stuart
Recommendations for EVO dyno tune in PERTH
  • Adam76
    Adam76
    5 years ago
    Hey guys, used to use Thunder tech many years ago for twin cam dyno tunes.
    Now have a 1996 Evo with a cam, 9.5 pistons, minor headwork, Dyna 2000 ignition and coil, and mikuni carb.... can anyone recommend a good turner that knows and works with carbs and evos?
    Oh, yeah. Perth based, thanks.
    Berms
  • Adam76
    Adam76
    5 years ago
    Anyone?
  • wello
    wello
    5 years ago
    Quoting Adam76 on 20 Apr 2020 01:03 AM
    Anyone?
    cant u go back to thundertek
  • Retroman
    5 years ago
    mate there's not much a "Dyno tune" can do for you with an older EVO. There are books around that can help you to help yourself "tune" it
    That's my take on the subject anyways.
    All anyone could do with a bike that age is twiddle the carby
  • Adam76
    Adam76
    5 years ago
    Anyone?
    Quoting wello on 20 Apr 2020 01:06 AM
    Hey wello,  yes I spoke to thundertech and they are happy to do it and have done plenty of evos in the past.
  • Adam76
    Adam76
    5 years ago
    Quoting Retroman on 22 Apr 2020 08:14 AM
    Thanks, but it had a mikuni carb and programmable ignition, both of which l know nothing about. Better be safe than sorry.
    Thunder tech are doing it, cheers
  • wello
    wello
    5 years ago
    Anyone?
    Quoting Adam76 on 22 Apr 2020 08:56 AM
    yep im sure you will be happy with the results , i doubt very much they would take it in if they couldnt do it .. good guys there : )
    5 years ago
    Really ? bit like pushing buttons on a laptop lol
    Thunder tech will get you sorted  after all the dyno does not tune the machine  Efi or carbie
  • Rivo
    Rivo
    5 years ago
    Thundertech dyno tuned my old 2005 FLHR Roadking with a Mikuni carb, got to say they had that running sweet for many years, very happy with their service.
  • Retroman
    5 years ago
    OK, not time for a "big dick swinging" match, but on numerous occasions I have had Harleys running way better after $HUNDREDS worth of "Dyno time".
    And yes, that was from " bit like pushing buttons on a laptop lol".
    I have watched "Dynos" being done , and thought silently to myself "By fuck that is NEVER being done to my bike!"...
    One of the other older riders in our group had several hundred $ plus a "stage 3" done to his 103 Dyna , and my "stock" 110 Softail SPANKED it.
    He was verging on distraught , sought and GOT a full refund from the "un-named" Perth WA Dyno specialist.
    I got his bike running way better "pushing buttons on a laptop" in 15 minutes and that included taking the side cover of LOL..
    Fixed his fuel consumption at the same time , it was woeful. he had dropped over 50K's to a tank , that's a LONG push !
    5 years ago
    That was part of my point a good tuner could tune a carbie at set points with more acceptable afr s
     With the use  of a dyno or afr gauge  with jets and screwdriver which would be / should be
    Better than just winging it  if you can do it on the rd great  a dyno is just a tool  like
    #2 philips or timing light   In this day and age laptop is the screw driver  I’ll go swing my dick
    I the sun  now  lol
