Online: kayno
Struts to suit softail 200mm
  • Softail Slimmy S
    Softail Slimmy S
    5 years ago
    Struts to suit softail 200mm Rear.
    Preferably 2017 fatboy low
  • steelo
    steelo
    5 years ago
    Hi SSS. I assume you're talking about a swingarm assembly?
    I think I have seen threads on here before. More than just swapping it over. Alignment of belt could be a problem. Having said that, breakouts have wide bums. Good luck with build. Post pics.
    Have a look at this youtube
  • Softail Slimmy S
    Softail Slimmy S
    5 years ago
    Hi mate,
    No just the struts as they have a different offset. I have a wheel on the bike in the original swing arm. I just didn’t want to space out my original struts to suit the wider fender as it’ll look a little odd. Rather a strut with a greater curve/offset.
    The fatboy has a similar tail light setup so at initial glance it’ll still have the protruding tail lights similar to the slim, instead of streamline lights.
    Check my pics
     Cheers.
