Online: Hilly, inkaporka
2019 Fat Bob rear brake pedal extension
  • Mesmer
    Mesmer
    5 years ago
    I've just had a Heavy Breather fitted to my 2019 Fat Bob and immediately discovered that, yes, it interferes with the operation of the rear brake i.e. I can only operate it with the very tip/inside edge of my right boot. Not ideal.
    Has anyone found an extension for the pedal to overcome this?
  • Daffy
    Daffy
    5 years ago
    I'm a shortarse so I had this problem with the standard air cleaner. My mate has a huge press and he put a kink in the lever and works great. Send me a pm and I'll message you a pic. Cheers
  • Far Canal
    Far Canal
    5 years ago
    Quoting Daffy on 12 Apr 2020 11:24 PMedited: 12 Apr 2020 11:25 PM
    Why don't you just post the picture?
    I'd be interested to see it too
  • steelo
    steelo
    5 years ago
    You can just buy an extended (wider) pedal. Fits the standard lever
  • Mesmer
    Mesmer
    5 years ago
    Quoting steelo on 13 Apr 2020 09:16 AM
    Appreciate that. I was thinking of that but just wasn't sure if the would fit the 20149 Fat Bob brake lever.
    Much appreciated.
  • Daffy
    Daffy
    5 years ago
    Quoting Far Canal on 13 Apr 2020 08:06 AM
    I did it!Bit embarrassed how easy that was.
  • Far Canal
    Far Canal
    5 years ago
    Nice job Daffy.
  • Mesmer
    Mesmer
    5 years ago
    Hi there, it's been a while since I made this thread but I thought I should add that the above doesn't fit the standard lever. To use it you need to first buy the billet lever which it bolts on to.
    Not sure how much the billet lever is in Oz. Probably a lot.
  • Mesmer
    Mesmer
    5 years ago
    Could you post a photo of this please?
    Thanks
  • imoo6170
    imoo6170
    5 years ago
    Quoting Mesmer on 01 Jun 2020 12:21 PM
    Thanks
    See post above from Daffy on 15 APR 2020 09:15 AM
