Rebuilting Rear Shocks
5 years ago
Okay,
So the Ikons are getting a little long in the tooth and need a rebuild. I can buy the rebuild kits from Ikon no prbs.
IS this hard to do? Anyone done this before?
Wideglider
5 years ago
Got Ikon's myself, one of the best upgrades I've done. I would imagine that the rebuild kits come with instructions.
There's probably a general YouTube video too, trick is always trying to find a good one though!
5 years ago
If you can compress the spring to remove it, and as they are designed to be disassembled (need to make a pin spanner), then the rebuild
will be easy !
The issue is how to refill with the correct weight and amount of oil, and then pressurize them with Nitrogen - (that is if they are gas
pressurized, and if not, they should be !) .
