Online: John.R
battery charger lead
  • wello
    wello
    5 years ago
    g,day just wondering if there is such a thing as an extention cord for the bike charging lead .. due to the way my bikes are stowed in the garage i cant lean over the bikes to attach the charger lead to the bike .. when i had my old ultra it had another lead coming down the right side of the bike so not a problem .. new ultra doesnt so need to sort something out  .. cheers
  • WideglidingNZ
    WideglidingNZ
    5 years ago
    Quoting wello on 05 Apr 2020 05:45 AM
    What sort of charger do you have? If hd you can buy a longer cord
  • steelo
    steelo
    5 years ago
    You can buy the charging pigtails easy enough. I used to have two on the 14 but you’re right. There’s only one on the 18. Else, normal extension cord to charger and sit that on the floor.
    You’re inventing issues otherwise.
    If you wanted to kill 2 birds. Buy one of those Rocky Mountain pumps (reviewed here) they actually have an extension cable in the pack
  • wello
    wello
    5 years ago
    yeh i have a harley charger , its not that the cord isnt long enough its just that i can only park it with the charge plug so its facing the side wall , even on its own it would be difficult leaning over trying to plug it in , but with another bike beside it its almost impossible ; /
  • wello
    wello
    5 years ago
    looks like that would do it, bit long but i could get it shortened i rekon  then plug in and reroute to the other side of bike .. cheers mate : )
  • Benno
    Benno
    5 years ago
    Look on flea bay, I got one of these and a USB plug to charge shit while out on the bike, have it mounted so i can plug in either to the USB or to charge the battery when at home.
    Battery Tender 08101486 Snap Cord Extension Cables - 6ft.
    BATTERY TENDER QUICK DISCONNECT USB CHARGER
  • imoo6170
    imoo6170
    5 years ago
    Can you not just re-route it from the left to the right side? Take off the seat and it should be connected to the battery so you should be able to pull it back up and push it down the right side?
