Online:
John.R
2 questions
2 questions
potluk
5 years ago
Hi guys. First question if anyone knows if a 110 lowrider s exhaust will fit on a 2014 103 street bob. Second if they do does anyone have a set to sell. There is quite a few fxdls on bikepoint but not many have original exhaust so there must be one or two out there somewhere. I am in adelaide so it would be best if i could get one locally. I have the vance and hines big radius at moment but they are too loud as i am thinking of riding to work more often and i start at 4am so dont want to upset the nieghbors. I have the originals for my bike but they are chrome and i like the look of the lowrider setup so just putting it out there. Cheers Potluk
5 years ago
Hi mate. Yes the low rider s exhaust will fit your street bob. Same size o2 sensors too. But the lower rider s exhaust has catylitic converter in the collector where it goes from 2-1 (and then back out to 2). The street bob exhaust is better as the cats are in the mufflers with clean headers. Best using your street bob headers with some good mufflers. Get the street bob headers coated in black?
Or otherwise you can get the low rider s exhaust on eBay and gumtree. They pop up there
potluk
5 years ago
Thanks for your reply Fatbat. Goes against the grain to quiet my bike down but as we go deeper into lock-down I may only be able to ride to work so for the time being if the cat in the collector is more quiet that is a good thing. Also wondered if the fatbob exhaust is the same as the lowrider s in chrome as my mate has a set off his bike. Cheers again Potluk
5 years ago
No worries potluk. They only make two types of exhausts for our vintage dynas. The staggered like what is on the streetbob and superglide I think, and the other one is the type they use of the low rider s, fat bob and wide glide I think. They are interchangeable. The only issue is that from 2012 onwards they went to a smaller oxygen sensor size. You can still fit a 2010 exhaust to a 2014 bike but you need to buy and fit adapters to make the oxygen sensors work.
Ive got a low rider s with a supertrapp 2-1 exhaust but toying with the idea of putting street bob staggered header pipes on it with s&s mufflers which will all need to be coated in black. Keeping the stock exhaust though sorry as I always do.
potluk
5 years ago
Thanks for your help again mate. Yes I also like to have a standard set for my bike just in case. Shame your not in Adelaide we might be able to work something out. Cheers Potluk
5 years ago
A dyna lowrider s stock exhaust just popped up in Sydney on gumtree for $200.
Have a look at e-go which does online organised freighting cheap from city to city using backloads and a depot to depot service. I’ve used them lots with success and not too much coin
potluk
5 years ago
Thanks heaps for the heads up Fatbat. Got on to the seller and he is going to drop off the exhaust at e-go tomorrow. Cheers Potluk
5 years ago
Excellent mate glad I could help and hope it works out to your plan. All the best
