HELP identifying these pushrods please
  • MattyWilson
    MattyWilson
    5 years ago
    G'day legends,
    I'm currently building a custom promotional bike for my brewery. First build. Also first post here on hdforums.
    It's a 47 hardtail frame with a John Trease custom shovelhead motor.
    I was informed by the previous owner that the motor is apparently 96ci. (He wasn't the guy who had the engine built unfortunately).
    This would mean its most likely an 80ci bored out and probably cammed and valved.
    I haven't removed the heads to verify, only the rocker covers to remove the pushrod tubes for powder coating.
    The pushrods are too long to remove / reinstall with the rocker covers on.
    I bought the bike not running but it only had a blocked carb, so cleaned that out and its definitely a DEMON of an engine.
    I'm having trouble identifying the pushrods and lifters that have been installed.
    I'm also unsure of how to set them back up after painting / powder coating.
    Details:
    Pushrod lengths at fully closed (wound-up / un-adjusted) position:
    FE - 274 mm
    FI - 268 mm
    RI - 268 mm
    RE - 271.5 mm
    32 TPI adjustment.
    I've drained the engine of oil and its been sitting for around a month so I think the hydraulic lifters are bled to their lowest position when I cycle the motor backwards.
    When setting back up I was going to follow this procedure.
    1. Base circle for each lifter. (Lifter at lowest position).
    2. Install pushrod and finger tighten to zero lash.
    3. 32tpi = 3.2 turns to .100" (.03125" per turn/.00520 per flat) down from there.
    4. Check pushrod still rotates by hand.
    Does that sound right?
    Any help would be greatly appreciated.
    Cheers Legends,
    Matty Wilson.
  • MattyWilson
    MattyWilson
    5 years ago
    Thanks or the info Hoodeng!
    The engine has done around 5000kms on it so I think the combination works ok.
    Do you think my setup procedure looks right for pushrod installion?
    Cheers legend!
