Online: John.R, Rextheute2022
BACKFIRE/BURBLEING
  • OILLEAK2008
    OILLEAK2008
    5 years ago
    Folks
    I had to recently remove the entire rear V&H muffler/header. I have not done this before. I reinstalled using a new genuine HD metal gasket that looked to be made from a compressed steel wool pad.
    So the bike now backfires/burbles and sounds like shit.  Have I fucked up the re-install?  After I heard the results of my handiwork I re-tentioned the flange nuts but it seems now to be worse?
    I assume air is getting in/out? Should I remove it all and try again?  Is there a better product than the stock HD  gasket?
    Cheers fella's.
    5 years ago
    Did you use the flat style gasket or the cone style ?
  • Ratbob
    Ratbob
    5 years ago
    Don’t know what bike it is but also check the O2 sensor and plug.
    5 years ago
    It may even be in the connection between the muffler and header, check clamp is tight
    5 years ago
    So.
    A:  Unless you can visually see a misaligned gasket then removal is best.
    B:  Several folks make gaskets but they are all about the same, so Harley are as good as any.
    c:  Dube check you used the correct gasket at the head end as there are two types.  Round and flat or round and cone shaped
  • Ken in Cairns
    Ken in Cairns
    5 years ago
    Putting the gasket is n the freezer overnight helps with the installation fyi.
  • OILLEAK2008
    OILLEAK2008
    5 years ago
    Sorry folks - should have mentioned the bike. Its a stock 1995 EVO.  The gasket was a HD item (not sure if the correct one) - it was tapered/beveled on one side and square on the other. I fitted it with the taper facing out to mate with the header pipe.
    My pipes are age related Vance & Hines so not sure if the shape of the mating edge shape of these makes any difference????
    5 years ago
    Quoting OILLEAK2008 on 24 Mar 2020 07:49 AM
    OILLEAK scroll back up to your first post, then go down one to second post & answer speedsters question
  • OILLEAK2008
    OILLEAK2008
    5 years ago
    Quoting speedzter on 23 Mar 2020 08:12 AM
    Hi - If 'cone' typ means one side beveled then yes. I put the square side in first with the bevel/tapered side facing out to contact the header pipe. I tightened it all up and since the burble did a re-tighten in case that fixed it. I did not.
  • OILLEAK2008
    OILLEAK2008
    5 years ago
    Quoting tussuck on 23 Mar 2020 09:06 PM
    So.
    Hi - I used a flat one side/beveled on the other. bevel side facing out.
  • bloodog
    bloodog
    5 years ago
    Quoting Ken in Cairns on 24 Mar 2020 12:44 AM
    bloodog like this post
  • robnicko
    robnicko
    5 years ago
    is the gasket seated all the way down evenly in the port and all remnants of the old one removed?
    sounds a bit like it may not be seated correctly and the header not sealing proper / square
  • OILLEAK2008
    OILLEAK2008
    5 years ago
    Quoting robnicko on 25 Mar 2020 08:54 AMedited: 25 Mar 2020 09:33 AM
    I wondered that but was sure I got all the old one out. Perhaps I stuffed up the flush install of the new one. I guess given what you good folk have said I need to remove the system again and try the re-install again but double checking everything as I go.
    Cheers fella's for the advise. The backfire has really been pissing me off. back to the hoist for me. Thanks one and all.
    OL
  • Muzza Wa
    Muzza Wa
    5 years ago
    For what it’s worth here is a link I used when learning how to change the pipes on my fatboy Lo.
    https://www.fixmyhog.com/video/proper-exhaust-gasket-install-002159/#
  • Muzza Wa
    Muzza Wa
    5 years ago
    Quoting bloodog on 25 Mar 2020 02:58 AM
    +1
  • OILLEAK2008
    OILLEAK2008
    5 years ago
    Quoting Muzza Wa on 25 Mar 2020 03:04 PM
    Thanks fella.
