Online: imoo6170
48058-08 part wanted
  • ralphski
    ralphski
    5 years ago
    spacer 48058-08 needed for my Springer.
    none in Australia.
    where in the States is the best option to get one sent out ?
    thanks boys
  • wello
    wello
    5 years ago
    have a look on here mate
    http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?Type=13&make=hdmc&a=708&b=27&c=0&d=2008%20FXSTSSE2%20SCREAMIN%20EAGLE%20SPRINGER%20SOFTAIL%AE%20(PT)%20WHEEL%20-%20FRONT%20WHEEL%20ASSEMBLY%20W/%20BRAKE%20DISK
  • RossW
    RossW
    5 years ago
    Quoting ralphski on 22 Mar 2020 11:29 PM
    none in Australia.
    thanks boys
    The actual spacer wouldn't be difficult to make for someone with access to a lathe. The other bit looks like a seal? That would be trickier but it might be possible to get from a generic bearing supplier.
  • ralphski
    ralphski
    5 years ago
    none in Australia.
    thanks boys
    Quoting RossW on 23 Mar 2020 01:24 AM
    i could turn one up @ work, but need the dimensions, as it looks as if someone left it out when a new tyre was fitted, FFS.
  • imoo6170
    imoo6170
    5 years ago
    Maybe try one of the springer groups on Facebook ie Harley davidson springer softail. There are a couple of helpful guys on it.
    Even if u find a dealer in the states with it they may not want to sent it due to Harley imposing bans on sending parts O/S.
    There is also an Aussie group Harley Davidson “ol’boy & Springers” AUSTRALIA which has quite a few US members
    5 years ago
    none in Australia.
    thanks boys
    Quoting ralphski on 23 Mar 2020 02:04 AM
    If the wheel has a spacer on the other side  get the inside and outside dimensions of that than
    Work out your length  .? Just a thought
