Shift Lever
Shift Lever
keithg
5 years ago
HI,
I have a new 2020 FXLR Lowrider, but for me the shift lever is about 1" too long as I have a small foot, size 8 boot. The standard lever is 9" but 8" would be better.
Does HD make a shorter one?
Smokey61
5 years ago
Quoting keithg on 22 Mar 2020 03:52 AM
HI,
I've got the opposite problem. boots have a patch for the shifter wear, but shifter contacts boot behind the patch. Need one an inch longer.
5 years ago
HI,
Not sure on that to be honest... Google may be your friend as some company 'may' make them somewhere.
If they are made of steel you could look to cut and weld.
imoo6170
5 years ago
Take you tape measure down to the local dealer and start measuring. I am pretty sure the shafts that the gear levels mount to are the same.
wello
5 years ago
just wear a size8 on ur right foot and a size 10 on ur left .. sorted : )
steelo
5 years ago
You can never have too many pairs of riding boots
keithg
5 years ago
Thanks guys, all sorted. Local HD had a shorter one.
