Online: softfat
rear axle cover fatboy
  • fatty10
    fatty10
    5 years ago
    hi people . been looking for a rear axle covers for fatboy. found plenty but when you have a look at what models they will fit. the description is except fatboy model. harley guy told me because of standard exhaust. i've got  radius curves on he said they'd fit. is he right?.thanks in advance
  • Muzza Wa
    Muzza Wa
    5 years ago
    Quoting fatty10 on 17 Mar 2020 11:02 AM
    I have HD rear axles nut covers on my Fatboy Lo and installed them while I had BR exhausts. If you want to cover the swing arm nuts then you need to loosen the rear mounting plate enough to get the cover on, took 5 mins.
    Check my picture on the Grenade post I made.
  • robnicko
    robnicko
    5 years ago
    the 'multi fit' covers are what I have on mine, front, rear & swingarm
    only issue is the exhaust side of the swingarm, the cover acutally touches the exhaust when suspension compresses.
    I solved this by putting washers between the muffers and mounting bracket to move them away from the bike by the thickness of the washer
    I have STD exhaust with S&S slipons
