Fatboy brake problem
Tiny.94.fatboy
5 years ago
Hello I'm new here I'm trying to take off the rear caliper on my 94 Fatboy but I can't get the 2 bolts that hold it on all the way backed out cause there hitting the swing arm
berserker
5 years ago
Can you post a photo? Im Not sure if they're the same as the later models
Tiny.94.fatboy
5 years ago
Got it figured out whoever had the wheel off last had it back way to far belt was super tight and that's why the bolts was not clearing the frame
berserker
5 years ago
All good mate. Glad you got it sorted
