Online: pat
indicator lenses
  • wello
    wello
    5 years ago
    i thought about changing my indicator lenses on the ultra to the dark ones to try match the bike a bit better, as i was in the shop having it serviced yesterday , so i saw the box on the shelf which seemed to also contain bulbs as well .. didnt buy them just yet but on the way home i also thought about doing the same to the sportglide ..but ive just realized that the rear indicators on my sportglide are also my stop / brake lights so im not sure if thats possible to do it on that bike .. has anybody done the same ?
  • TC883
    TC883
    5 years ago
    Hi Wello, the combined stop/turn/tail light units are sealed LED units, so you can't change the lenses to the smoked ones unfortunately. I had the same issue on my Iron and endeavour up changing the fronts over to the smoked lenses and orange bulbs, but left the rear ones unchanged. I have seen some guys tint the rears with tinted clear coat paint but it I have never tried it myself. Hope that helps you. TC
  • wello
    wello
    5 years ago
    Quoting TC883 on 06 Mar 2020 01:03 AM
    thanks mate , had a feeling that was the case   . cheers : )
  • micathia
    micathia
    5 years ago
    just off the topic, I am also searching indicator lens these days.
