Rocker C's V-shape handlebar on Dyna
  • micathia
    micathia
    6 years ago
    Hi,
    Anyone tried Rocker C's V-shape handlebar on dyna (Wide Glide) particular?
    Would the pull back too much for Dyna?
  • bloodog
    bloodog
    6 years ago
    I have a set I would sell off my 09 FXCW  Rocker
  • micathia
    micathia
    6 years ago
    Quoting bloodog on 28 Feb 2020 12:52 AM
    i m still researching tho. just want see some real.pics dyna using it.
  • Ratbob
    Ratbob
    6 years ago
    You’ll need to check the bar centres I.e. the distance between the holes in the top triple tree to see If they’ll fit.
    Do a forum search for
    “stock handlebar reference chart”
  • bloodog
    bloodog
    6 years ago
  • micathia
    micathia
    5 years ago
    Hi, sorry a dumb question, isn't this supposed to be chrome?
  • Ratbob
    Ratbob
    5 years ago
    Quoting micathia on 09 Mar 2020 10:41 AM
    Me thinks the chrome were on the Rocker "C" version, usually Blue, Blue frame, chrome fork legs, oil tank, etc.
    The grey was on the Rocker as you see with grey wheels, fork legs, rocker covers, oil tank and softail etc
    As you can see from Bloodog's pics, the riser is a solid one piece, not two as on a WG so you gotta make sure the hole centres line up.
  • Retroman
    5 years ago
    I have the same in Perth WA , in chrome , from a Rocker C
    If anyone has interest , BUT they would be a complete cock of a thing to post !
  • bloodog
    bloodog
    5 years ago
    I changed to fat bob bars
  • micathia
    micathia
    5 years ago
    Quoting bloodog on 11 Mar 2020 09:27 PM
    how do you compare this with original V-bar?
  • bloodog
    bloodog
    5 years ago
    Quoting micathia on 12 Mar 2020 01:38 PM
    I have had dirt bikes all my life and the mini apes felt strange to me, plus I had a breakout previous to the rocker.
    My opinion was the v-bar on the Rocker looked shit
    Now with the few changes I recon my Rocker looks a lot better
    Handling wise also much better with the flat bars
    Having said that Rockers don't handle well
  • micathia
    micathia
    5 years ago
    I think the stock bar on my wide glide looks shit. But handling pretty good. Hesitating if I want to change it.
  • bloodog
    bloodog
    5 years ago
    Quoting micathia on 14 Mar 2020 01:28 AM
    And its a lot of work changing bars
  • FXDF08
    FXDF08
    5 years ago
    Rotate the bars downwards more (make sure indicators are clear of the tank) and I think they tick the boxes for both form and function? Personal choice of course.
  • bloodog
    bloodog
    5 years ago
    Fat bob bars
  • micathia
    micathia
    5 years ago
    Quoting bloodog on 14 Mar 2020 03:12 AM
    Fat bob bars
    I have seen this picture before. The owner used 2 inch riser extension from DKCustom.
    I bought 3" extension from them already.
    The stock bar is 3" rise on a 5" riser. Dyna fatbob use the same riser with drag bar.
    My theory is, if I use 3" extension and a flat drag bar, then I shouldn't need the change the cable and everything else. The only concern is, I don't want pull back too much. I don't know 3" extension + 5" riser and fatbob drag bar, would give me excessive pull back.
    The one in photo is one of my mod option. The other one is Rocker C V bar.
  • Mr.Mow
    Mr.Mow
    5 years ago
    This is a biltwell 8” chump mini ape on 2” risers, stock wiring, clutch and brakes all work. But only just.
