Artificial lighting for cleaning purposes
  • wello
    wello
    6 years ago
    G,day all .. just so wondering what would be the best type of lighting just for the purpose of cleaning , cleaned my bike inside the garage the other day and it looked great until I wheeled it outside in the sunlight .. then it looked shite and a whole bunched of marks and water stains .. anybody tried any different types of lighting for cleaning ?
    6 years ago
    Quoting wello on 27 Feb 2020 01:57 AMedited: 27 Feb 2020 03:19 AM
    well, I don't know if this is the best for cleaning. but have a LED fluro replacement that is real bright if you had two long ones spaced out, it would be hard to beat ( if you can't see then, go to spec savers )
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    I have old school fluro tubes, but use true daylight tubes, not warm or cool white.
    Led is great option too, but check the spectrum specs beforehand.
  • Wideglider
    Wideglider
    6 years ago
    You still won't be able to see everything properly with any type of room lights.
    I swear by using an LED headlamp with focus adjuster for a wider spread, that way you can see what you're cleaning under bike & in nooks & crannies.
  • steelo
    steelo
    6 years ago
    Overkill. User leaf blower to get rid of water between fins and instruments, switches nooks crannies. Just chamois off paint and chrome. No way should you get water marks.
    6 years ago
    Thats not an easy answer as for normal paint correction purposes they actually use a range of light colour temps (mind you its easy to spend $200+ on just one 50w LED multi-temp lamp - https://www.waxit.com.au/collections/lighting)
    LED is the way to go.  For home use look for 2700k, 4500k and 6500k which will give you a good overall view, so just buy some LED floro tubes on ebay or bulbs or the like.
    If the bike looks like crap in the sunlight though, I would start with the tools/products/processes your using.  you should be able to get to 90% good in a shed with the right kit and 100% in a shed with kit + lighting
  • wello
    wello
    6 years ago
    the initial problem started with the leaf blower, i used it for to long instead of just blowing off the worst of the water so in effect it dried it to quik and hence the water stains. did end up getting them off and i have just this morning had it coated with toughseal and its looking great again .. but still my lighting is shit house and i need better : )
  • bloodog
    bloodog
    6 years ago
    Inox buy a 5lt bottle pour into a hand spray bottle and spray every thing but the tires and break pads
    Bike will look a million dollars
  • steelo
    steelo
    6 years ago
    Heck BD. Straight diesel would be cheaper and you won't have kiwis following you down the road
  • Odin
    Odin
    6 years ago
    I use 2 20 inch LED light bars and have them on the shed wall. Cant beat the LED stuff. Might be an over kill, but I can see what I have missed when cleaning and servicing
  • Wideglider
    Wideglider
    6 years ago
    Don't see having the bike in the shed well lit is 'overkill'. I still recommend LED headlamp for cleaning in the shed, especially to see under the bike & under the guards etc - ceiling or wall lighting just wont do it!
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    I wash mine outside under the portable awning, then move it back into the shed after I dry it off to complete the paint, alloy and chrome polishing, and the wax coat on paint. My shed has huge doors so pretty much have good natural light with the overhead fluros as well..
  • wello
    wello
    6 years ago
    yesterday i had the ultra  toughseal coated , its looking good so be nice to keep it that way.. looking at buying a led stand light that ive seen on ebay ..(arlec  20 w- 1600 lumens)
    dunno if thats any good or not but it must be better than a single standard buld in the middle of my garage roof lol. .. by the way does anybody else use any of the toughseal products ?
    6 years ago
    Quoting wello on 28 Feb 2020 01:53 AM
    Be keen to understand if they did a paint correction prior to applying the toughseal.
  • wello
    wello
    6 years ago
    Quoting tussuck on 28 Feb 2020 09:33 PM
    toughseal is a 2 part application , he used both bottles
    6 years ago
    Quoting wello on 29 Feb 2020 12:24 AM
    BUT did he cut and polish first?
  • wello
    wello
    6 years ago
    Quoting tussuck on 29 Feb 2020 04:06 AM
    no , not required on a brand new bike
  • Vic
    Vic
    6 years ago
    4 banks of double fluro's in the shed with a couple of the opaque roof sheets which let quite a bit of light in.
    Like to do a decent job when detailing but don't get too carried away, they get dirty pretty quick!
    6 years ago
    Quoting wello on 29 Feb 2020 10:29 AM
    ummmm, ok
  • steelo
    steelo
    6 years ago
    I recently revisited meguires wet look polish for the bikes after only using Harley polish. Impressive. Reasonably economical, Easy to apply and polish off.
