Online: softfat
103 ci Cylinders
  • Phatty
    Phatty
    6 years ago
    Looking for 103 ci Cylinders in good condition standard bore size to suit 2010 Softail. i have a new set of Stanard pistons and want to turn a 96 ci it into a 103.
  • Lushy
    Lushy
    6 years ago
    Surely you can bore your cylinders to suit?
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    He may just be hoping to find a set cheaper than the machining cost, but if he has the Pistons, I would bore the barrels to suit them.
  • Phatty
    Phatty
    6 years ago
    I asked all over Brisbane no one wants to bore them out, They all say buy Aftermarket barrels.They won't even work on the heads.
    Buy S&S or we can't help you. Cheaper to buy new than get them done they reckon.
    Just finished talking to Heavy Duty and he might have takeoffs from a 2012 that has had a 110 conversion done.
    6 years ago
    Any decent engine machine shop should be able to bore cylinders. Dont limit yourself to motorcycle shops as car engine builders will likely be the go.
    Headwork is another story but reputable places around Australia to send heads to that have proven track record with Harley heads. Not cheap though and if you're only going to 103 when 106, 107 or 110 is an option then Headwork may not be for you anyway. Good.luck in any event
  • Lushy
    Lushy
    6 years ago
    Maybe give Ollie Logan a call ?
  • Phatty
    Phatty
    6 years ago
    Simon at Heavy Duty called back and said he had no Jugs left but they will bore mine out, I never thought of car engine builders fatbat yeah I will ring around .
    I want the heads done ( Skim 10 thou,valve job and a good cleanup ) while I've got them off. I'll also give Ollie a cal tomorrow Lushy.
    6 years ago
    Quoting Phatty on 20 Feb 2020 12:01 PM
    I would go to Olie !!
    he did my sporty's flywheels & balanced plus welded the pin. well I could not be happier as this is a rigid mount ( no rubber mounts or counter balancers ) and it is real smooth. going to someone that has a good knowledge & knows how to do the job right. makes a difference, also always better to resize your old barrels than to use new. also make sure barrels Torque plate resized ( I would expect anyone resizing HD barrels to have torque plates but never know )
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Call Hoody about you heads. :)
  • robots
    robots
    6 years ago
    Car shops probably won't have plates.
