Online: WideglidingNZ, softfat
toughseal paint protection
  • wello
    wello
    6 years ago
    g,day .. possibly looking at getting the ultra treated with this toughseal product .. has anybody used it and if so how do you rate it ?
    6 years ago
    How much?  Its 'just' a ceramic coating - I'm sure I have a writeup somewhere here about the topic.
    Is it DIY?
  • wello
    wello
    6 years ago
    Quoting tussuck on 16 Feb 2020 12:57 PM
    Is it DIY?
    i ran into a guy while i was down at the new perth harley shop in midland, he was detailing a new bike that was sold  (ultra) so i asked him how much to do mine with this toughseal stuff .. i dont think its a ceramic like some other but i could be wrong .
    anyway $400 to do entire bike. and hes mobiles so comes to you.
    6 years ago
    Thats not a bad price...IF he does the proper job.  Should look like:
    • Wash
    • Decontamination (iron removal)
    • Clay bar
    • Wash again after all above
    • Paint Correction
       o New bike would be single stage (swirl removal)
       o Old bike most likely two stage (cut and then swirl removal)
    • Ceramic coat (any claims of stuff lasting up to 5 years is total crap - 2 is the norm).  NOTE:  most of this stuff comes in a 30ml or 50ml bottle and he will use like 10ml-20ml for a bike so make sure you get the bottles when he is done as you will be paying for them.  typically thats about $80 - $100 ish of the price.
    • Then typically an overcoat for the ceramic whch is the hydrophobic coating (I think that’s the part 1 + part 2 in the toughseal kit)
    Could this be $400? Very easily as the cost of the paint correction equipment (and more importantly the actual products) are not cheap. Should take about 2 hours or more. (I can spend 6 hours on a small car to do a proper job)
    - Ask what steps he does and see if they fit with above
    - Ask what brand of products he uses (there are not that many out there and the diff between chit and god is pretty clear)
    - Ask if you 'have' to use a certain brand of product to wash your bike from that point on... In reality any good Meguires or the like will do a good job.
  • wello
    wello
    6 years ago
    Quoting tussuck on 17 Feb 2020 02:02 AMedited: 17 Feb 2020 02:12 AM
    • Wash
    • Clay bar
    • Paint Correction
    yeh ive seen the little bottles of that stuff.. look really small.. however this toughseal stuff looks to be quite large bottles.. he says its a ceramic product but its seams to be quite different to the others .. looks more like a normal type of wax in a bottle so be farked if i know .
  • Soapbox2627
    Soapbox2627
    6 years ago
    I got 4 bottles of it, will do the Roady one day
  • wello
    wello
    6 years ago
    spoke to the guy again today .. he says its    toughseal ceramic QFX .. apparently u cant buy it and its only distributed to trained  detailers , so anyway ive boked him . for next thurs .. only problem i have now is geetin the farkin water stains off by bike ... jeez black is a pain !!!!!!
    6 years ago
    Quoting wello on 17 Feb 2020 01:22 PMedited: 17 Feb 2020 01:23 PM
    Hang on...
    Question:  Is he doing any paint preparation at all or 'just' applies the product and that it?  You should not have to do a thing in prep.
  • Soapbox2627
    Soapbox2627
    6 years ago
    Quoting tussuck on 17 Feb 2020 08:28 PMedited: 17 Feb 2020 08:28 PM
    Hang on...
    I had the Ranger done brand new, dropped off for 11, picked up at 2.
    he gave me the rest of the bottle
    I dont know what prep he done, I'd guess he had lunch also
    6 years ago
    Okay...well I guess if your happy with the outcome then all is good! Perhaps I'm just too OCD...lol
  • wello
    wello
    6 years ago
    Hang on...
    nah mate , in my infinite wisdom i decided to clean my brand new bike as it was covered in dust from a ride the day before .. so i hosed it down and then decided to used the blower vac on it to dry it off .. i thought i had done a good job at first , looked great in the garage.. but then i wheeled it outside in the sunlight and  faaaaaaaark what a mess !!!!
    i normaly dry off with a shammy but i didnt want to put any blemished on the new paint .. that didnt work out as planned so now i gotta go get something to remove all the water stain marks .
    6 years ago
    Hang on...
    Quoting wello on 18 Feb 2020 12:53 AM
    Try a vinegar/water mix for the waterstains as they are normally mineral based.
    Shammy = 40 grit sandpaper.  Invest in some top notch microfibre towels instead. and hosing down never works....lol..but good try.
  • JFE
    JFE
    6 years ago
    Quality drying towels do a good job, I’ve found. Better than a shammy.
