ignition key question.
  • micathia
    micathia
    6 years ago
    Hi
    I bought a 2nd hand 2016 dyna wide glide. First time on dyna.
    Just a question about ignition key. Do I have to lock ignition all the time? my work place and home are pretty safe, if every time I don't lock the ignition, just turn it off and elave like that. Does it drain battery away?
    many thx
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Don't have the lock it, just select the off position.
  • micathia
    micathia
    6 years ago
    Quoting Ken in Cairns on 09 Feb 2020 11:24 PM
    thx.
    6 years ago
    My only thought would be...
    I lock my steering ALL the time, and it's become a simple reflex as part of turning off the bike.  It means I do not have to do any special thinking etc when parkign up outside of the normal safe zones at home.
  • micathia
    micathia
    6 years ago
    Ok, maybe its me being superstitious?
    I bought this one home last Friday:
    1. first time ignite at about lunch time Friday, no problem;
    2. second time ignited late afternoon, failed to start, battery out;
    3. then on Sat I bought a new batter from Harley dealer, charged up, did not lock the ignition overnight;
    4. Sunday morning it started, but not strong start, a slow startup;
    5. then I locked the ignition Sunday night;
    6. Monday (today) morning, I started, a normal start; and locked ignition at work;
    7. Then came to this site asked the question in OP;
    8. went out for lunch, didn't lock the ignition; after lunch, a slow start again.
    Could this be a battery drain out somewhere? Or ignition problem? or actaully I DO have to turn the key, lock properly?
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    The lock just stops the switch from being turned, it doesn't have any electrical connection..
    If the FOB isn't at least 3 meters away it can be consistently polling the bike, but that usually kills the fob battery.
    I would be having a look with a meter to see if there is current draw with the key in the off position.
    Maybe the electric side isn't fully isolating itself.
  • micathia
    micathia
    6 years ago
    Just after some research,.. it seems some dyna models have this "slow start" (like chug chug chug chug boom) when engine is hot.
    I will see if mine is the same.
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Cylinder head decompression valves might be a bit dicky.
  • Mr.Mow
    Mr.Mow
    6 years ago
    I’ll answer your question with this...
    ‘There’s a key hole on my dyna? Oh shit there is? Huh learn something new each day..’
  • micathia
    micathia
    6 years ago
    now everyday I am able to start it no fail. but it is always chug chug chug chug (4 times) boom. Is this normal for Dyna?
  • Big Steve
    Big Steve
    6 years ago
    On my daily I never lock it, its a 2014 with 90,000km and rattle can paint. If it gets pinched the theif is doing me a favour.
    On my fun bike I lock both the ignition and steering lock.
  • micathia
    micathia
    6 years ago
    Quoting Big Steve on 12 Feb 2020 11:51 PM
    Cool. You are at Yarra Range, we are very close actually. I am in Nillumbik.
