Online:
Merv
Latest upgrades - 120ci dyna
DJP_120ci
6 years ago
Haven’t posted around here for a while, just thought I’d share the latest list of upgrades.
Bike was last dyno’d at 125hp 135 ft pounds.
The list of changes are,
Fresh pistons and rings, cylinders bored/honed +.010”
625G cams replaced with 640G cams
55mm throttle body replaced with 58/62mm throttle body
4.9 injectors replaces with 5.3’s
Oil pump replaced
Heads services by hoody, valve springs replaced.
Exhaust changed to D&D fat cat.
Assembled and tuned at Neville Lush Racing.
Made 143/143.
Picture shows as it sits now and how it looked when I bought it.
Cheers Dylan
Jay-Dee
6 years ago
Nice work, it's a good thing you've got the new seat or it would blast you off the back onto the road when you twist the throttle.
6 years ago
Impressive in every way! Not to be a negative Nelly but are you still using your factory bottom end or replaced/welded things up?
6 years ago
looks good on paper, have you taken it to the track at all?
And any problems with the rear wheel spokes?
DJP_120ci
6 years ago
Thanks boys.
JD - the seat is so much better when you give it a squirt.
FB - the crank is an R&R cycles 4.500” stroker crank balanced and welded. Run out measured at .0015”. To be honest I’m no expert on any of this, I just ride the thing.
KK - haven’t had a chance to run it down the track, but it is on the list. For the meantime I’m just terrorizing the streets.
What do I need to look out for on the rear wheel?
6 years ago
Well that sure answers the concern about the bottom end.....ride on and hard!
Far Canal
6 years ago
Quoting DJP_120ci on 08 Feb 2020 12:04 AM
edited: 08 Feb 2020 12:26 AM
Thanks boys.
Policemen, in a car, with sirens and flashing lights.
6 years ago
Thanks boys.
Hey that is great!!
I think building a bike with a killer motor, that's he ultimate, testing at the track.
Baloffski
6 years ago
Fuck thats got power /torque, definite as KK says, out at the track.
Was just thinking years ago you could have a few drivers licences, through no fault of your own.
Example : I lived in SA, then went to Qld for a year, back to SA, briefly, then on to WA for a year, then with NT being lived in, for over the period to change to your licence, then passing to NSW, for a period.
So you get the idea, some peoples had multiple drivers licences, as you would definitely need if ya hit it on your rocket.
Sadly, can not comply like that anymore.
6 years ago
Thanks boys.
DJP missed your question, well I only had a little 95 c I d twin cam dyna, carb . I was taking it to the track all the time. & it could run constant low 11's. I road it to willowbank QLD a few times & home to Sydney, also went down Heathcote VIC once, mostly raced in Sydney. started with stock HD spoke wheels, I noticed the spokes on the drive side, where they hold to alloy hub. Had turned all the holes in the hub like egg's so put a stock HD cast wheel on rear kept spoke on front ( I love spoke wheels ). also even though I never broke a belt drive, I thought as I road to QLD to race then road home to Sydney, I thought it wise to change to chain drive & also had an outrigger bearing support to give the axle more support, as I had bent heaps of rear axles in past on Harleys I owned that I raced. then next thing to happen was every bolt holding Sproket to wheel, broke off on start line, I was doing quick 60ft ( for what I had ) & the track had a bit of stick on the line, was bracing for the rear thrust & one of the broken bolts, stuck between Sproket & swingarm, locked rear wheel up & went over the bars about 60ft from the start line. also another time I broke the rear rubber mount.
Having said all this the 88" sporty I have still has stock HD spoke wheels & belt drive, it goes hard but never been to the track yet ( live about 300km from track now ) have not had on Dyno yet as an old Carb& still running it in (17,000km last I checked ) but I'll be on Dyno to tune it soon, just to check afr is safe up high.
DJP_120ci
6 years ago
Thanks krash, I’ll keep an eye on all the things you mentioned!
I plan on going away from the spokes sooner or later for a set of mag wheels.
Would really love a set of BST wheels, but the price scares me and need to do some research Them a bit more.
6 years ago
Quoting DJP_120ci on 10 Feb 2020 03:46 AM
The lighter the wheels the better!!
