Online: Merv
1986 FLHTC: Correct Front Axle Bearings
  • JustinCase
    JustinCase
    6 years ago
    Hey guys,
    I've searched the interwebs high and low without an answer.
    Can someone tell me if the following Simkins bearings will fit my front 3/4" axle.
    Bloke behind the counter said "no worries mate, they'll fit".
    6 years ago
    Post #8 in this thread.
    https://www.hdforums.com/forum/evo-classic-models/1310804-wheel-bearings.html
    And good question too...My 86 is due for a set as well.
  • Far Canal
    Far Canal
    6 years ago
    Just used a set of these in my back wheel for an 84 FXWG
    I see they are different to your numbers. On the front of the packet, but the same on the side.?
    You'd think a bearing shop oughta know.
    Did you not take in the ones you removed when buying yours?.
    Beware also some of these bearings may need to be shimmed, so look out for shims when you take them out. Thankfully my rear ones did not need shims.
  • John.R
    John.R
    6 years ago
    The end play would need to be set regardless as you'd be changing the race too.
    6 years ago
    Yep, and I normally do that dry (ie not grease packed) as I find it too hard to get a good reading once the grease is in.  Is that nromal or just me?
  • JustinCase
    JustinCase
    6 years ago
    Far Canal,
    Re "Did you not take in the ones you removed when buying yours?."
    No mate, thought I'd grab them first. Get the job done quicker.
    I'll be checking for shims and such.
  • Far Canal
    Far Canal
    6 years ago
    Quoting JustinCase on 06 Feb 2020 04:54 AM
    Far Canal,
    Did not worry about shimming mine.
    There were no shims in there for the same bearings beforehand so cant really see why you'd have to for new ones.
    "Motor Head tussuck
    05 Feb 2020 10:06 PM
    Yep, and I normally do that dry (ie not grease packed) as I find it too hard to get a good reading once the grease is in.  Is that nromal or just me? "
    That is what I was told by the spare parts guru that I know Tussuck ,so it is not just you. You are probably spot on.
    Beats me how you are meant to do this though.
    Where are the shims meant to go?
    If you could extrapolate John R, that would be most interesting for me and I guess Justincase.
  • John.R
    John.R
    6 years ago
    Far Canal,
    Quoting Far Canal on 06 Feb 2020 08:35 AMedited: 06 Feb 2020 08:55 AM
    "Motor Head tussuck
    I also shim when they're dry, just a bit easier.
    Tell me if Im tellin you how to suck eggs, but here is a quick explanation.
    Inside your wheel hub, in between your  bearings is a spacer.
    If this spacer isnt there, when you tighten your axle, it will crush the bearings into the races and they'll be fucked in no time.
    Because Timkens use a press in race, there is two options to avoid the bearings being crushed.
    First option is an internal spacer that comes in different sizes (Can be marked by colour bands). Here are some examples. You can see they're specific, but slightly different sizes. This lets you set the correct amount of play (so the bearings arent crushed, but also arent too loose) For this, you would need to have a bunch handy.
    https://www.easyr.com.au/wheel-hub-partctr-spacer-orn-4.420-long-use-same-c
    https://www.easyr.com.au/wheel-hub-partctr-spacer-wh-4.448-long-use-same-co~300304
    https://www.easyr.com.au/wheel-hub-partctr-spacer-yel-4.434-long-use-same-c~300303
    Second option is a set length spacer, and then the use of shims at one end of the bearing (doesnt matter which) to get the correct length.
    Here are some of the shims. I was lucky enough to borrow different packet sizes from a local indy, and just pay him for the ones I ended up needing.
    https://www.easyr.com.au/shim-wheel-brg-0.032-flh82-99-most92-99-pk10
    https://www.easyr.com.au/shim-wheel-brg-0.016-flh82-99-most92-99-pk10
    https://www.easyr.com.au/shim-wheel-brg-0.008-flh82-99-most92-99-pk10
    The process can either be done properly with a dial indicator, or you can rough it. Just chuck the wheel in a vice, put the axle through with all the spacers, shims etc as if its going on the bike, use a bigger spacer on one end so that when you tighten the axle nut it actually torques the bearings, then you give it a tug and pull, and a bit of a spin. You want it to spin without binding, and ideally feel a little bit of play so you know the bearings arent getting crushed.
  • Far Canal
    Far Canal
    6 years ago
    Thanks John,
    But if the recess the outer race sits in (on the hub) is machined with a definite stop  on both sides of the hub (you know, you press,hammer in that outer race and it just cant go further) and the spacer that goes between the inner rollers is made to the right length from the factory then is there really a need to do it?.
  • John.R
    John.R
    6 years ago
    Yes, you will still need to check it, and shimming will still likely be needed. If you look at how precise the hub spacers are you can see why. You're spacers going up in incremements of 3 tenths of a millimetre or so.
    Same concept applies to the sealed bearing, except with those being a 1 pc bearing, you can feel the point where you need to stop tapping in, so no shims are necessary (or possible really)
    Even with the lip of the hub, you can install sealed bearings too far to the point they'll wear prematurely.
  • Far Canal
    Far Canal
    6 years ago
    Great explanations John, thanks.
    Gotta say it seems to be a complicated way of installing wheel bearings compared to other brand bikes whose wheel bearings (ball type) just tap in to the stopped recess with no need for shimming just re-use the spacer. It would make it a hassle to replace buggered bearings if you were stuck in some one horse town out woop woop way.
  • John.R
    John.R
    6 years ago
    It requires a bit more effort up front (and maintenance like greasing), but the timken is a far superior  bearing compared to later model sealed. I can't count the amount of stories ive heard of sealed bearings collapsing in 15-20k kms and leaving people stranded out in the sticks.
    Also, care needs to be taken when seating sealed bearings as the same concept applies.
    Not seated far enough and the bearings will run on the inside edge of the bearing. Seated fully (which Is what most people do as they assume the hub will stop it at the right spot) and the balls will rub on the outside of the bearing.
    Same thing, spacer shouldn't be too loose, but it also should be able to be wiggled and moved a bit.
    6 years ago
    Just buy the longest spacer and then sand/file/machine it to the right length.
    ALSO, the inner bearing race can be a bugger to remove.  If your struggling then weld a bead around the bearing surface; as when it cools it contracts and pulls the race with it - they then just tap out without an issue.
